Dual/Tandem Seal Piping Plans
The API 682 plan 52/53 arrangements for tandem and dual seals respectively show the buffer/barrier fluid inlet (BI)& outlet (BO) connections on the outboard seal with nothing connected to the flush (F) connection on the inboard seal.
Will the buffer/barrier fluid always be able to remove the heat generated from the inboard seal faces or might you expect to see say a plan 11/13 on the inboard seal?
RE: Dual/Tandem Seal Piping Plans
The Plan 52/53 would generally take care of the cooling.
In my experience I have seen over 95% of Plan 52/53 systems *without* the Plan 11.
As JJPellin says, some have it, some dont depandant on the application.
Milkboy
In cases like these a Plan 11 will not remove enough heat to help, generally beacuse the process conditions are part of the problem. And again in most of these cases the process fluid precludes the use of a Plan 21 or 23 because the product sets up when cooled significantly. Think Coker or Atmospheric Tower Bottoms pumps.
To effectively deal with these applications your best bet is a Plan 32 with a cool, clean, compatible flush fluid and your Plan 52/3, or a Plan 54 (imagine a lube oil skid to support the seal with filters, pumps, and heat exchangers instead of relying upon a pumping ring within the seal to circulate the barrier fluid)with a heat exchanger and large reservoir sized for the service.
Then you also have to worry about your buffer/barrier fluid. Is it capable of removing enough heat withtout degrading? Many users have resorted to heat transfer fluids because they are some of the few fluids available rated for such temperatures. There are others that use specialty barrier fluids from ExxonMobil, Chevron, or Royal Purple(to name a few big names in barrier fluids), or those who take chances with fluids rated for lower temperatures.
I'd be intested to hear if anyone has had experience with Royal Purple BF 910 or Dowtherm HT.
Then again, you could go old school with a single metal bellows seal with a steam quench. Environmental and Safety concerns are driving more people to double or tandem seals here.
