pressure on surface
pressure on surface
I have a problem defining a surface. How can you create a surface where you can define a pressure onto it? On an excisting surface I want to put a circular pressure on it. I think that you must create in advance a surface and then define a presssure to this surface. But when I do this, the force doesn't work on the part... that surface is just going through the part. How can I fix this?
Thank you in advance
RE: pressure on surface
