de minimis conditions ??
4
What is de minimis conditions?  Can't find a reference on this.
RE: de minimis conditions ??
4
Of insufficient significance to warrant judicial attention.
www.blm.gov/nhp/Commercial/SolidMineral/3809/deis/glossary.html
This is a short form of de minimus non curat lex. Latin for "the law does not bother with trifles."
www.indiainfoline.com/bisc/jmhd.html
A use or operation carried out at a sufficiently low level so as not to require planning permission.
plans.torbay.gov.uk/written/cpt17a.htm
De minimis is a Latin expression meaning about minimal things, which is mostly used as part of de minimis non curat praetor, in the sense that law is not interested in trivial matters.
en.wikipedia.org/wiki/De_minimus
If you type define:whatever into google's search box then it pulls up definitions, as above.
Cheers
Greg Locock
Greg,
Thanks for the Google tip.  I didn't know that one.  Star
ASM
One frequently used adjective that may serve as a synonym is negligible.
Mere bagatelle
