Creating model in Ansys
I have created bar model of the retractable roof
made of steel in autocad, and I would like to export it
to Ansys. I would like to model airflow and calculate
wind pressure coeficients on the structure.
Questions:
- which is the easier way, import dwg to solidworks,
  create iges, import to ansys, then create areas
  and volumes, or create 3d solid in Solidworks and
  after that export to Ansys. Or maybe exist other
  way to creating?
- I will use flotran modul of Ansys, but I don´t
  have practical examples of using this modul.
  Where can I found some.
Thnx,
Robert
RE: Creating model in Ansys
I'll do the following:
-import the swg into Solidworks
-create the solid model
-optional export the model into a Parasolid file type
-open Workbench to attach the active geometry (Solidworks must be opened) with all the advantages of this procedure (see the documentation) or import the Parasolid file and do the analysis; if the analysis can't be done into Workbench, export to file to Ansys.
This is just my option.
Instead of Flotran, take a look at CFX,
Yes, it really works.
I have tried it on the prism with using parasolid file.
Now I must deeper study Flotran, or CFD
to model my aim.
With this import Ansys automatically chose
an element type, or I must define it?
Now im going to create a space around the prism.
I saw some tutorials in the program, but
they didn´t have economical printable version
(less usage of paper). Is it possible to download
on the web, or export somehow these tutorials.
Robert
There are some options to choose when you create the mesh. If you are in need for a special type element, you must go down to Ansys. But a lot of work has been done for and you can concentrate on the analysis itself.
Regarding the documentation, for the printed version you must pay for it, as far I know at least for me.
Rtmpxr,
I solved this tutorial, but there are some
differences.
http://www.andrew.cmu.edu/course/24-ansys/htm/f4_car.htm
First of all, the geometry of the boundary is given
unsymmetrically in this tutorial on the axis of the car, not as is shown in the figure.
The car isn´t situated on the bottom of the boundary
as in the real life on the street. The values of these
tests could be comparisable with the real situacion.
The final velocity plot  of air depends on the distances X, Y from the boundary, and don´t depend on Z?
On the final plot there are velocities 6 times
bigger as the starting velocity of air 24.6m/s.
How is it possible?
Thank You so much,
Robert
In the car region the streamlines come closer together, and the area between them decreases. Since the density is constant, the velocity must increase according to the principle of mass conservation. For constant density flow, wherever the area between streamlines decreases, the velocity increases.
