'Drag and drop ' method for sketch based features
I m fairly new to catia. Can 'drag and drop' method be used for sketch based features in Part design. Suppose I make a pocket in a body..can I drag and drop it to make another pocket in the same body ? how will I retain both the pockets?
Thanks and cheers
RE: 'Drag and drop ' method for sketch based features
You can Copy-Paste the sketch and use on a new location in the same body (only if you dont have some restrictions regarding using multifeatures in the same body).
Fernando
