Pulsation problems in high-speed/low-speed installation?
Has anyone had any experience installing high-speed seperable recipocating compressors (1000-1200 RPM) in parallel operation with low speed recipocating intergals (300 RPM)? We are proposing to install three high-speed electric units in parallel operation with five existing intergals to discharge into the same pipeline (16"). I am curious if anyone has experienced pulsation issues in this type of installation. Old and new units will be four stage units.
RE: Pulsation problems in high-speed/low-speed installation?
Yes, I've done that (never four stage, but I have done 3 stage).  My approach is to handle pulsation on the skid, then you don't have to worry as much about sympathetic pulsation frequencies.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The harder I work, the luckier I seem
