SW & AutoDesk "Vault" integration
Our company utilizes AutoCad, but also SW. Plan is to utilize AutoDesk Vault program for a drawing control system. Has anyone had any experience with this kind of setup? Pros/Cons?
Any experience with Vault itself - pro/con?
RE: SW & AutoDesk "Vault" integration
You might want to consider using PDMWorks instead
which comes with Solidworks Office Professional.
The PDMWorks Vault allows check in of Solidworks, AutoCAD, and other file types. I do not have any experience with the Autodesk Vault program.
