model tree icons are not shown
Hi. I've moved my seat of wildfire 2.0 onto a new computer. Everyting works, but the model tree doesn't look the same. The icons that identify features, parts and assys do not appear. It is very hard to quickly see if something is suppressed or if it is a datum plane or a curve, etc.
I'm using the same config.pro and config.win files as before.... I don't use a tree.cfg file.
Can anybody help?
thanks!
Pete
Can anybody help?
thanks!
Pete
RE: model tree icons are not shown
Go to the -Settings, -Tree Filters and make sure features are turned on. Save settings file to a location.
Use config.pro option
mdl_tree_cfg_file and browse to that location.
Thanks for your help. Maybe it is a graphics card issue?
Pete
Most of the newer high end cards have application settings.
We use nividia FX series
and set the app setting
to Pro/ENGINEER Wildfire
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
thanks!
pete
Control Panel/Display/Settings/Advanced/Quadro FX 1400 Tab/OpenGL Settings
There is an area that says "Custom OpenGL applications setting"
This is set to Pro/e or wildfire.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
does enable 8 bit double buffered overlay planes
doesn't force copy swap
doesn't wait for vertical retrace
does enable OpenGL hardware acceleration
Do you think there is any info available from PTC on this? I'm thinking of asking a friend to search the ptc site for links.
thanks again
pete
