Are patents worth anything?
I've been working in R&D for several years (mostly MEMS and small electromechanical products) and noticed that it has generally never been considered to license any IP from anyone - unless a working product was already available and then we would purchase the product anyway (the fact whether it had any IP or not didn't matter in this case).
Also when we realized that we might infringe a patent we would always find a way to work around it or find an alternative solution. In addition when competitors would infringe on some of our patents we didn't go after them because it was considered too costly and time consuming.
I realize that patent lawyers make a considerable amount of money with patents, but what about inventors? Are there any inventors profiting from their patents? Are there any inventors or engineers that came up with a neat idea and some corporation actually licensed it?
Or is your corporation paying some small guy licensing fees for his idea?
RE: Are patents worth anything?
Jerome Lemuelson, whatever you think of his capabilities, left his entire patent portfolio with a foundation populated entirely with lawyers, whoc gleefully go after anyone appearing to infringe on one of his patents.
Large corporations leverage their patent portfolios in a similar fashion. Fairchild Semiconductor was sued by Hitachi in the mid 80's for patent infringement. We were able show that a sizable portion was sufficiently questionable that we got away with settling for $7 million on a $50 million suit.
TTFN
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
It was downright annoying, but they identified the fan engine as the better propulsion device early on. One of their first designs was a fan engine. They also predicted the value of the turboprop.
At GE we were encouraged to write patent disclosures because of the license value to the company. Now the european consortium is producing their own derived versions for the latest airbuses.
An individual patent by itself may look like it has little value and cover little. However, If there is a competitor in the same market who has patents, at some point the two companies may begin to butt-up each other and one or both companies may file infringement lawsuits. These are usually settled out-of-court by each company cross-licensing their patents. Few companies want the expense of long litigation. In such a case, a patent that appears of little use becomes a valuable item of exchange as part of the settlement and saved much more money than it originally cost to get.
Another situation I have seen was a case where a electromechanical product was designed. A minor patent could have been applied for, but the cost benefit was not obvious. However, a second company copied the product and applied for and received a patent. The cost to the first company to then prove prior art and beat down the copied patent was more than the cost saved by not patenting.
Minoxidil was one such drug. It had previously been marketed with the caveat that higher doses were not beneficial. Yet, as the patent on the original Minoxidil ran out, a higher dose Minoxidil was patented and continued to make money.
In fact, one of the biggest public health debates ongoing in poorer countries is the suspension of patent rights on a variety of drugs to get the cost down by letting companies infringe on the patent. Since they did not pay for the development of the drug, they can manufacture at a lower cost.
TTFN
Btw I heard this before, that some company patented something that was already state of the art. I personally think this is really annoying and there should be simple ways to prove prior art. I wonder whether you can just send the plans of the product to yourself and not open it. This way you have the proof (post stamp) that you invented it, before it was patented by some other company without having to spend thousands of dollars on a patent lawyer - or what do you think?
The crux of the problem is like starting a new business, less than 10% of all patented ideas are feasible, marketable and desirable.
Your assumption that a single inventor can come up with "plans of the product" is the problem. A typical product requires multiple disciplines, a production line, a producible design, etc. Since you have no production, you cannot ensure designing a producible product. No matter what you do, producibility is king and the person that makes that happen, by definition, has the right to patent his improvements on your design.
TTFN
Obviously there are very simple products that could be managed by a single person. Think of that SAM splint mentioned before. (I'm not talking about pharmaceuticals, lasers or engines.)
But what can the small guy do to prevent a big company from patenting his idea and then stop him from selling it? (I'm not talking about a big company stealing the idea.)
Don't you think if he sends the product to himself is proof enough that he invented it before it was patented and should allow him to sell it?
Having proof of precedence simply allows you to try to overturn a patent in court. It would still be years before you could claim victory, after which, you would then spend years trying to collect royalties.
Also, I believe that it's impossible for a single inventor to develop an idea well enough to do what you're asking, particularly, since it's unlikely that a competitor will have the identical product.
This all takes time. The basic patent process does not require product nor plans, just an idea that can be described narratively. By the time you actually come up with product drawings and plans, etc., it could years after the basic idea was invented, which is time lost.
Not having a patent puts you at a grave disadvantage
TTFN
Lets say you invented a simple spoon that changes color when food is above a certain temperature (so that the customer doesn't burn his mouth) - the plastic is already available and so is the mold for the tool - so R&D is practically zero.
You know that you'll never generate more than $1 Million in revenue (not worth a law-suit). Why would it be a grave disadvantage if you wouldn't have a patent?
I'd like to see a statistics that show how many patents actually were worth anything (made money before they ran out)? Is it more than 0.1%?
For instance the turbocharger was invented 1905 by a single inventor. Was it a great invention? Yes and definitely better than most. Did the inventor make any money with it? No.
It seems to me that paying for a patent can be like paying for an insurance that you don't need or even worse might not cover you anyway.
The majority of other patent holders invent mostly useless stuff; God only knows why those people bother. The majority of non-company patents don't make money simply because they're essentially useless products. The most famous useless patent I can think of readily is the chewing gum saver for saving chewing gum overnight; it came with hardware for mounting on a bedpost.
It's a grave disadvantage to not have patent protection on a real product because there's almost always someone who can undercut your price. Without patent protection, you have no legal recourse to stop them from copying your product, undercutting your prices and putting you quickly out of business.
TTFN
P.S. coloured spoons - prior art now, but could have been patented, and could well have been worth more than $1million if done so.
How about this:
http://en.wikipedia.org/wiki/Cat's_eye
Interesting links about the inventor and monies made...
Rgds
Harry
Basically - a single inventor sued and won a $1.3Bn settlement against one of the largest players in the industry. Billion - with a B. He did have a small company in place which I'm sure helped, but the bottom line is:
This man's patents, past and future, netted him a Billion bucks.
Nevertheless, a single simple patent for someone who sees the need and the idea to meet the need can be worth a lot of money. Take, for example, the stereo cassette adapter that allows you to hook up an external audio device (CD, iPOD, etc) by using a cassette-shaped module in you cassette player. This consist of only a coil with couples to the tape player head magnetically. This was developed by individual(s) in Millwakee. From the time the idea occurred to them until they had a working example required only about 1/2 a day! In royalities and licenses, this quick idea has resulted several million dollars income!
Patents can eventually worth something, depending on the country you are living, for instance in China and India it worth virtually zero, no matter the product is. If it is sucessfull, it will be copied by thousands without you ever know who is doing it.
In the developed countries where IP is still enforced this process can also be paintful.
I remember once I saw a cartoon in a newspapaer, where a samll inventor was going to a big corporation trying to license his invention and then a big laywer was saying to him:"Our corporation holds XXXX thousand patents. For sure you are infriging some of them. You would be better off it you just give us your invention for free".
The patent system has become a complete inutile joke. The reviewers are utterly clueless and can't comprehend the term 'novel',.. never mind the invention.
What's with the recent 'pay every 4 years of lose your patent' bullsh**.
I think it's obvious what the patent system has become.
