Table, Parameter, Feature Syntax
Can anyone point me to a document that at least attempts to explain or show the necessary syntax required to reference different pieces of information in the model to be used in either a parameter, table repeat region, relations, etc...?
Thanks.
Thanks.
RE: Table, Parameter, Feature Syntax
Support
Technical Support
Download reference documnents
Enter PTC web account username and password
Set the following values:
Product: Pro/ENGINEER
Release: Wildfire 2.0
Document Type: Help Topic Collections
User Role: All User Roles
Press the 'Browse the reference documents' button
Download the file.
Open the ZIP file and you have a full set of Wildfire 2 reference PDF files. Thousands of pages material that with a little effort you should find an answer to your question.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
