Concrete bridge surface finish advice
3
I am involved in a design process of an architecturally elaborate bridge, made up of both precast and CIP elements. The bridge is being designed and constructed by a State agency, but will be turned over to our City for ownership/maintenance upon completion.
My question regards recommendations for the surface finish for the bridge. The State agency has 3 progessive classes of finish which begins with general surface finish (essentially just removal of bulges, fins, rock pockets, etc.), Class 1 finish - general finish plus grinding and coating with latex paint, and Class 2 finish - all of the above plus an intermediate floating (i.e. sacking) of the surface before coating.
At the City, we typically don't paint our bridges because of (later) appearance and maintenance issues (i.e repainting), but we do sack the finish (a Class 2 finish, as above, but no paint). I would be satisfied with this finish type on this bridge, too, but the architect is very concerned that grinding by an over enthusiastic worker will remove  or round over his sharp detail lines, and that the floating process would give a rough texture, and round over details even more.
Assuming we can address the architect's concerns by carefully spelling out the acceptable surface finish guidelines, I'm wondering if anybody has any experience/recommendations for the application of a pigmented surface sealer (probably concrete gray)in lieu of the paint? The majority of our surfaces would be the railings, and vertical faces of columns, piers, outside faces of girders, and fairly extensive modular approach walls. Would a pigmented sealer look OK? How long would these sealers last on surfaces that are not subject to traffic loads?  We would also like some graffiti protection on the piers and approach walls, though. Incidentally, in our City and State we do not use salts for the infrequent snow/ice removal, so we don't need an elaborate protection system.
Any advice would be greatly appreciated.
Thanks.
Steve R. Yates
City of Portland Oregon
Office of Transportation Engineering
RE: Concrete bridge surface finish advice
stevey,
I’m a bridge design engineer with a consulting firm and have specified concrete sealers from Elite Crete Systems (www.elitecrete.com) and sealers and anti-grafati coatings from TK Products (www.tkproduct.com).  These products have worked well and the end product has a very nice appearance.  I’m not sure about the long term performance of these products, but I’m sure your sealer manufacturer could give you some durability/performance data.
About your surface finish concerns, I would also add a note somewhere in the plans or specs that requires the contractor to finish a small test area that must be approved before he can finish the entire bridge.  That way, you and your architect will have a chance to see the finish in the field and discuss your concerns with the contractor before the entire bridge is finished.
Hi Steve,
Your requirement to allow no paint and sacking is similar to the State of California requirement. I have built maybe thirty bridges already and I believe the solution to your problem is to obtain the Caltrans Standard Specifications. To download a copy, just go the to State of California Web site, then go to the Department of Transportation, then to the Engineering Service Center (ESC), then to Office Engineer.
Fiji
