Friction Loss Books
Friction Loss Books
Anybody know of any books/software that does friction loss calculations - looking for:
- basic 'sump to pump to process' pumping system - no multiple nodes, simple piping.
- methods of calculating losses for mining slurries, paper stock, viscous liquids.
Currently I use the cameron hydraulic book, but the calculations always seem to need 'tweeking' between the paper solution and the real solution.
RE: Friction Loss Books
I think its cost is around $50 now, but it is worth every penny for me (petroleum).
As far as determinging friction loss for Slurries, you might want to contact Svedala. In the past, I used a book that they produced which highlights friction factors for slurry pumping based on slurry concentrations, particle sizes, etc.
Jonathan Ives
Project Engineer
Transalta, Alberta Thermal Plants
Duffield, Alberta
Another one, which I have only scanned through and followed some examples is "Slurry Systems Handbook" McGraw Hill.
Depending on the case they require knowing the limits and possible range for the estimates.
I have also found a complete formula (no need for Darcy graph) in the book for Tour and Andersson. This is also a very good in general for boilers, piping and valves etc.
