Two Phase Pump???
Two Phase Pump???
Daer Gentlemen,
I would like to ask you guy that " Do we have any pump that can pump Gas & Oil in the same time?"
or "Do we have any compressor that can handle large quantity of oil?"
TDP = 300 psi
gas 75 MMSCF/d
oil 1000 BBL/d
How to transfer oil and gas in the same pipe line?
TDP = 300 psi
gas 75 MMSCF/d
oil 1000 BBL/d
RE: Two Phase Pump???
Seperate, compress/pump, and then recombine. You need to simulate the line in order to get the right line sizing for two phase flow. To large a diameter and the liquid phase separates and slugs, to small and velocities add to much friction.
Good luck
A quick search on google came up with +3600 hits and no. 3 from the top was Framo. (hint: Google have a special "toolbar" for IE that you can download.)
Best Regards
Morten
