Picking up the centroid?
I was wondering if anyone knew of a way to highlight or identify the centroid of an area in Autocad.
thanks
Barry.
RE: Picking up the centroid?
Make your area a region (use the "region" command). Then Tools > Inquiry > Region/Mass Properties
CODE
(defun C:CENTROID (/ ent vla_poly vla_region centroid)
(vl-load-com)
(if
(and (setq ent (car (entsel "\nSelect a polyline: ")))
(eq (cdadr (entget ent)) "LWPOLYLINE")
(eq (vla-get-closed
(setq vla_poly (vlax-ename->vla-object ent))
:vlax-true
(progn
(setq vla_region
(car (vlax-safearray->list
(vlax-variant-value
(vla-addregion
(vla-objectidtoobject
(vla-get-document
vla_poly
(vla-get-ownerid
vla_poly
(vlax-safearray-fill
(vlax-make-safearray
vlax-vbobject
(cons 0 (1- (length (list vla_poly))))
(list vla_poly)
(setq centroid (vlax-safearray->list
(vlax-variant-value
(vla-get-centroid vla_region)
(vla-delete vla_region)
centroid
(princ)
...borrowed somwhere in the www
Lothar
ADT 2004
ACAD 2002
