Distance Learning, MEng (MSc) in Chemical Engineering
Dear All,
Can you please advise where it's good to get a distance learning (following to a master degree) for Chemical Engineering? But it's to be the world-recognized education/university!
thank you,
Jeyx
RE: Distance Learning, MEng (MSc) in Chemical Engineering
That is a very personal decision that shouldn't be taken lightly. You need to look within yourself for the answer, because there are to many differing opinions on this forum. Only you can determine your personal goals, and evaluate the best way to achieve those goals. For you maybe it is a good decision to make. For someone else maybe it is not... or vice versa.
Also look at the program. Maybe if you need "distance" education, there are better programs more suited to this type of learning than the "world renound" program.
Good luck
Wes C.
In this house, we OBEY the laws of thermodynamics! - Homer Simpson
