Non-master drawings
Non-master drawings
Dear friends,
I am appeal to you with one question, which relates to drawings. Normally I use non-master system of drawings to avoid messing of large assemblies. The problem is with substitution of small similar parts inside an assembly n-m drawing. Even an identical part (just saved under another name) losses all utilities in drawing (dimensions, part attributes....). Only way I find is to put the complete set of part+dwg file inside of assembly and both save as. Then delete set and input only a part.
And second, is any way to create a part list with geometrical values (semi-finished dimensions).Currently, I do by linking expressions.Thank for answer.
