Computing angular errors in Excel
I am trying to create a Excel spreadsheet that will produce
the amount of error between expected and actual measurements. I am entering negative and positive numbers in a degree/minute/second format.
ie.
Expected results Actual results Error Amount
________________ ______________ ____________
Horizontal/Vertical Horizontal/Vertical
-10 deg / +35 deg -10:20:10 / 34:54:10
ie.
RE: Computing angular errors in Excel
Here is a quick and dirty sample to get you started. You will of course need to add some error checking to ensure that there are 2 colons in each input cell! This takes first input from A1 <Cells(1, 1)> and C1 <Cells(1, 3)> and posts the result in E1.
CODE
Dim myDegree As Integer
Dim myMinute As Integer
Dim mySecond As Integer
Dim myStart
myStart = Split(Cells(1, 1), ":")
mystartangle = CDbl(myStart(0) + myStart(1) / 60 + myStart(2) / 3600)
Dim myEnd
myEnd = Split(Cells(1, 3), ":")
myendangle = CDbl(myEnd(0) + myEnd(1) / 60 + myEnd(2) / 3600)
mydiff = myendangle - mystartangle
mysign = Sgn(mydiff)
Debug.Print mysign
mydiff = Abs(mydiff)
myDegree = Int(mydiff)
myMinute = Int(60 * (mydiff - myDegree))
mySecond = Int(3600 * (mydiff - myDegree - myMinute / 60) + 0.5)
Cells(1, 5) = IIf(mysign = -1, "-", "") & CStr(myDegree) & ":" & (myMinute) & ":" & (mySecond)
End Sub
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Steam Engine enthusiasts: www.essexsteam.co.uk
degree call out? What is wrong
with decimal degrees?
Select the cell, <right-click><Format cells><custom><@>.
If somehow you have a string of '10:20:10' use =value(10:20:10) to convert it back to a number.
