Infrancing Lines on Dimensions
I used to see infrancing lines on dimensions - when dropping them in a drawing. I liked that - I could line-up dimensions "on the fly". It went away & I want it back. Please advise...
Windows 2000 Professional / Microsoft Intellimouse Explorer
SolidWorks 2006 SP01.0 / SpaceBall 4000 FLX
Diet Coke with Lime / Dark Chocolate
Lava Lamp
RE: Infrancing Lines on Dimensions
I believe it's tool-> options -> System options -> drawings-> check "detail item snapping when dragging center"
Grant
Applications Engineer
SW2006 SP 0
IBM InteliStation Pro M
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1100
Thanks... I think that was it. But I thought I remembered getting the lines as I was placing the dimension text - this gives me the lines only when I'm dragging the text to line-up the dimensions. But - I'm not complaining. This is still better than I had it.
Lava Lamp
