ANSI Y14.5
6
ANSI Y14.5
ANSI Y14.5
I know this may be a basic question but I have one of our designers using a parallel w/in .005 to control a basic dimension of 1.500. My understanding is if he wanted to use a control that covered both parallel and height that a profile tolerance should be used.
I looked in the book and it shows a tolerance zone for parralel but never in relation to a basic dimension.
Hope this question is clear enough that someone can help me with this...
RE: ANSI Y14.5
Your understanding is correct. To control both parallelism and height , related to a BASIC dimension, use profile. A parallelism tolerance zone does not relate to a BASIC dimension.
RE: ANSI Y14.5
Unless their is some other control on that surface like profile I would have to say the designer is wrong.
RE: ANSI Y14.5
Here's what I would do... I would call out this surface parallel to datum A to within whatever tolerance is neccessary and then I would add a height dimension to the surface in question and add a tolerance of ±0.005 or whatever is appropriate. I don't think that I would use a profile tolerance in this situation, although I don't think you would really be wrong to do so. Lastly, for some reason I can't quite pinpoint, I feel it's neccessary to point out that you can attach the feature control frame to the height dimension on your drawing. It's true that you cannot use a basic dimension with your parallelism callout, but why do you need one? Just put a tolerance on it and call it a day. :)
RE: ANSI Y14.5
case closed
Cheers
RE: ANSI Y14.5
Parallel tolerance on a surface should not be shown with a basic dimension but with a +/- tolerance. Make sure the the tolerance specified is with the tolerance range.
Tip - Reflecting the surface with profile of a surface is best since it does control the location of the surface, parallelism and also flatness. If you have a profile of a surface tolerance of 0.5 mm from a basic dimension. The 0.5 is the range of a bilateral tolerance. Nother can be above or below this value.
Basic dimensions are theoretical dimensions and are not tolernaced.
RE: ANSI Y14.5
dingy2,
   The thing that is necessary is that we control the position of the surface, as well as its parallelism.  Your +/- tolerance achieves this, as does the profile tolerance recommended by caseynick, above.
   I can also do a composite tolerance in which the profile tolerance is 1mm, and the parallel tolerance is 0.05mm for example.  I do this a lot on optical mirror mounts, where the position does not matter much, but the angle is absolutely critical.
                             JHG
RE: ANSI Y14.5
Thanks guys I was able to convince him and all is well
The links from gsagolla helped a lot
Thanks again
