Gas Pipeline and Compressor Station Blowdown
Where would I find a comprehensive method for calculating the pressures and temperatures vs time resulting from blowdown and pressurising of pipelines and compressor stations?
Dennis Kirk Engineering
www.ozemail.com.au/~denniskb
RE: Gas Pipeline and Compressor Station Blowdown
Dennis,
I think you are more likely to get good answers to this question if you post in the "Piping and fluid mechanics engineering" forum.  There are a few NG people who hang out there.  They may see your post here, but I think that you would more luck over there.
Its quite a coincidence to see you here - I surfed into your web site purely by chance yesterday. Very nice!
Katmar
Thanks Katmar,
I have posted the same query on the Piping ... site.
It is the combination of thermodynamics, fluid flow and heat transfer that makes this case both complicated and interesting. Hence my posting here.
MOC, the method of characteristics is probably the best technique to analyze flow problems in which pressure and temp are fuctions of location and time, ie x and t.
