Error number 2176
Error number 2176
Error number 2176
I have a form with a Combobox and the follow code:
Private Sub Form_Load()
Dim bestand As String
Dim lijst As String
Dim pad As String
pad = "c:\bal"
bestand = Dir(pad & "NN*.xls")
 Do Until bestand = ""
    lijst = lijst & bestand & ";"
    bestand = Dir()
Loop
Me.cmbBestanden.RowSource = lijst
end sub
There are totally 1945 files beginning with NN*.xls.
So far no problem.
Now are the files expand to 2500 files!
And now I get the fault warning from Access:
Error number: 2176
The setting for this property is too long.
And the ComboBox is now empty.
Who can help me with this problem?
Greetings,
mulderm
RE: Error number 2176
Hi mulderm,
I think your string "lijst" is just too long, switch to an array to load your files, then change your combo box RowSource to:
CODE
Me.cmbBestanden.RowSource = Join(lijst, ";")
HTH
Todd
Thank you for the information.
mulderm
