Why out-of-round holes?
We're finding some bores in our parts aren't very round (as measured with a 3 point bore gage). They are 1.125 Dia x .375 dp in aluminum. The bore diameter varies by .005. I'm surprised this could happen as the bores are made with a boring head on a mill. Has anyone seen this before? How could they be so out-of-round with a boring operation?
RE: Why out-of-round holes?
Manufacturing Freeware and Shareware
http://mrainey.freeservers.com
What size is the bit?
What are the feed rates?
Or any other information about the tooling.
It could be the aluminium is not that stable and “moves” after the bore is finished, maybe a finishing cut on the bore as the last operation (if practical) would solve the problem?
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
If a spindle has enough play in it to cause a finishing cut on a bore to be .005” put of round then it should be in a scrap yard.
Boring is far more accurate than reaming, if a spindle has that much, the reamed hole will be a real mess.
Neither do I.
Scott
This is a good lesson in resolving problems if something has been working and quits all of a sudden. The first question always is "Has anything changed?" and push for answers.
