Delphi & MS Access
Delphi & MS Access
Hallo,
I have some problems with saving a long text (longer then 255 characters) into MS Access database.
When I want to save it, the error screen pups up and it contains:
[0] General SQL error.
[Microsoft][ODBC Microsoft Access Driver] Invalid descriptor index
[Microsoft][ODBC Microsoft Access Driver] Invalid precision value
The data base is MS Access 2000: field ôtestö is defined as ômemoö. I am using Delphi 6, ODBC 5.2, TQuery:
Code for saving:
procedure TaOrganizacija.Button1Click(Sender: TObject);
var
sql_niz: String;
begin
sql_niz:='INSERT INTO organizacije (test) VALUES (:test) ';
QOrg.Close;
QOrg.DatabaseName:=sys_dbalias;
QOrg.SQL.Clear;
QOrg.SQL.Add(sql_niz);
QOrg.ParamByName('test').AsString:=mOpomba.Text;
Try QOrg.ExecSQL;
Except
On E: Exception Do
begin
ShowMessage('['+inttostr(E.HelpContext)+'] '+E.Message+#13#10);
end;
End;
end;
The error occurs if I want to save in this field text, longer then 255 characters.
If I use QOrg.ParamByName('test').AsMemo:=mOpomba.Text; , the error screen pups up and it contains:
[Microsoft][ODBC Microsoft Access Driver] String data, right truncated (null).
If the text is shorter than there is no problem. If anyone already had similar problems, I would be thankful if you could share the solutions. Any kind of tips would be helpful.
Thanx
SaX
Code for saving:
var
sql_niz: String;
begin
QOrg.Close;
QOrg.SQL.Clear;
Try QOrg.ExecSQL;
Except
On E: Exception Do
begin
end;
End;
end;
Thanx
SaX
RE: Delphi & MS Access
Maybe another solution?
THX
SaX
The MVP's in these forums are doing a fantastic job.
There is also a chance that your problem is described somewhere in Delphi newsgroups/forums
Good luck,
Engin
Access memo field cannot be indexed, but you can certainly read and write them, filter on them etc.
1) What is QOrg.ParamByName('test').AsString declared as?
2) Is it a ShortString or a String/ANSIString? From the little bit of Delphi that I do know, ShortStrings are limited to 255 chars - that might be where your problem is.
3) Has $LongStrings$ been turned off when building the program?
The limit is
"65,535 when entering data through the user interface;
1 gigabyte when entering data programmatically."
But as XWB suggests I don't really think that is the problem.
