OptionButton selections in excel
Hi
I am having trouble using OptionsButtons in a UserForm. I wand the user to make a choos between three types of options. If he clicks OptionsButton1 row 23 & 24 is to be hidden from the user in worksheet 1( in excel). If OptionsButton2 or OptionsButton3 is clicked the rows should be shown. Also the value in cell E20 and E21 is to change. My code (as you can se below) makes the change in E20 and E21 but do not hid or show row 23 & 24. Can some one help me whit how to write the code sow it works.
Thank in advance Markus
__________________________________________________________
Private Sub CommandButton1_Click()
If OptionButton1.Caption = "OK" Then
Sheets("sheet1").Cells(20, 5).Value = "I-suport"
Sheets("sheet1").Range("A23:F24").Select
Sheets("sheet1").Range("F24").Activate
Sheets("sheet1").Selection.EntireRow.Hidden = True
Sheets("sheet1").Range("A25").Select
Sheets("sheet1").ActiveCell.FormulaR1C1 = "12"
Sheets("sheet1").Range("B22").Select
End If
If OptionButton2.Caption = "OK" Then
Sheets("sheet1").Range("A22:F25").Select
Sheets("sheet1").Selection.EntireRow.Hidden = False
Sheets("sheet1").ActiveCell.FormulaR1C1 = "14"
Sheets("sheet1").Range("H21").Select
End If
If OptionButton3.Caption = "OK" Then
End If
Unload Typeofsuport
End Sub
Private Sub CommandButton2_Click()
Unload Typeofsuport
End Sub
Private Sub OptionButton1_Click()
Sheets("sheet1").Cells(20, 6).Value = "I-suport"
End Sub
Private Sub OptionButton2_Click()
Sheets("sheet1").Cells(20, 5).Value = "T-suport"
Sheets("sheet1").Cells(20, 6).Value = "T-suport"
End Sub
Private Sub OptionButton3_Click()
Sheets("sheet1").Cells(20, 5).Value = "pi-suport"
Sheets("sheet1").Cells(20, 6).Value = "pi-suport"
End Sub
End If
End If
End If
Unload Typeofsuport
End Sub
Unload Typeofsuport
End Sub
End Sub
End Sub
End Sub
RE: OptionButton selections in excel
How about:
CODE
Sheets("sheet1").Rows(23).Hidden = True
Sheets("sheet1").Rows(24).Hidden = True
End If
HTH
Todd
