Field Instruments on PV and Piping?
Dear All
Field Instruments such as Thermowell, Level Gauges, Transmitters etc that are mounted on Pressure vessel and Piping are found to contain Welding and on some instruments we find reservoirs.
Which Code governs from the point of view of Welding and NDE and Pressure testing requirements for the field instruments? Are there ANSI guidelines for the same, Does ASME Specify any specific requirement for field instruments.
RE: Field Instruments on PV and Piping?
For either in-service or a new vessel, the Code of Construction rules must be followed for any material and weld detail for direct attachment of the appurtances to the vessel pressure boundary.
When i have to procure these field instruments, i need to specify the NDE requirements and Welding requirements.
I would require hydrostatic testing. With hydrocarbon products and other high pressure applications I prefer magnetic level indication and assorted technologies in lieu of level gauge glasses. If using gauge glasses offshore they require a protective shield.
John
in ASME VIII-1 non.Code vessel can be 6 in or less welded or not.
The instrument has to be meet/certified to ANSI stds.
genb
Instruments like level gauges usually are not required to be hydrostatically tested as they fall under the category that a protype has been tested to failure so the specific item is not required nor desirable to be field tested.
