Scrubber for small kilo reactor?
There is a possibility that our Lab may escalate making specialty organic chemicals to a pilot size 50-Gal reactor with rupture disk operating below 14 PSI. Does anyone know whether current environmental regulations would require a scrubber or containment system and if so, any idea as to what kind of scrubber system! Thank you
RE: Scrubber for small kilo reactor?
m777182
However, you have not stated specifically what you are going to be doing or where you are doing it. There may be environmental regulations, OSHA, or zoning issues regarding the use and manufacture of specific chemicals. You may also have issues regarding the suitablity of using your existing structure (fire code, etc.) if that is what you are intending.
You should also run this question by your insurance underwriter.
