Bent Plates and Minimum Bend Radius
I don't understand the "minium bend radius" concept. In the ASD, page 4-174, a 1/2 in A36 plate has a minimum bend radius of 1.5 X thickness.
Let's say I'm designing a skewed connection and I need a bent plate, does the minimum bend radius mean I HAVE to bend the plate 1/2 in?
Halp!
Halp!
RE: Bent Plates and Minimum Bend Radius
It is just the radius of the bend. Not the angle or offset. Lets say you bent the plate 90 degrees. Any connection would need to be held back 3/4" from the inside to allow for the bend radius. Kind of like the fillet of an angle or other hot rolled section. Hopes this helps.
Aluminum in aircraft has minimum bend radius of about 3 to 4 times the thickness (depends on alloy and heat treat). Bend radius is the inside radius after bending. Bending is typically done with a brake that has a tool to form the specified radii. If the sheet is bent to a tighter radius is likely to crack. You can actually bend the sheet to a larger radius to ensure you do not crack the metal. Steel can be bent to a tighter radii.
Hope I shed some light on the issue.
Lutfi
i think a big factor in minimum bend radius is the temper (which may be evident in "A36", so excuse my ignorance). if you bend it in the annealled condition (similar to O condition in Aluminium) and then heat treat to the required strength, you may be able to bend more tightly.
i guess really you can bend as tightly as you like, so long as you don't get cracks forming (and perform a crack check inspection).
Kinda scary.
(And yet we don't hear of bent plates fracturing all over the place in service.)
Hg
Eng-Tips policies: FAQ731-376
I did some deep "web mining" for anything to do with bending sheet metal. I first went into my cold-formed steel books but found little (they're about using the fabricated pieces, not about fabricating the actual pieces). Then I started thinking about sheet metal fabrication and such. The best info I found was at http://www.massey.ac.nz/~odiegel/bendworks/. I downloaded their paper "Bending." It gave a formula that related a "bending allowance" to bending radius. It explained everything to me.
Basically, that 4 in x 4 in bend plate is going to be a little bit longer than 8 in. Intuitively I'd say "of course," I'd just never given the issue much thought.
What exactly is the minimum temperature for specified "hot bending"?
I've gone looking for it and haven't found it. The closest I got was a metallurgist saying that nothing below the transition temperature could be considered hot bending--but you can't go near that transition temperature and still be sure that you had the same grade of steel you started with. I've taken to calling it "heat-assisted cold bending" instead, not that that really solves anything.
The other thing to worry about is bending the steel while it's in the "blue brittle" range (roughly 400-700F), which not only increases the likelihood that the steel will crack during bending but also can leave the steel embrittled afterward.
Hg
