Time-delay between starting of multiple motors
I have asked the question in the Electric motors & motor controls engineering Forum:
See the original question in thread237-136811
I would appreciate it if anyone can give his/her comments on the time-delay between two or more motors during start-up (for a conveyor) from a mechanical viewpoint. (Each drive a motor-gearbox combination)
The question is answered from an electrical viewpoint but I would like to hear what you think from a mechanical perspective.
Many thanks
Ralph
Failure seldom stops us, it is the fear for failure that stops us - Jack Lemmon
Make the best use of Eng-Tips.com
Read the Site Policies at FAQ731-376
RE: Time-delay between starting of multiple motors
http://www.howdenbuffalo.com/Products/gyrol.htm
However, the same question would apply to multiple drives with fluid-couplings: Are there any delay necessary between the start-up times of the different drives from a mechanical viewpoint? From an electric perspective the time-delay can be very short, but not simulataneous, due to the high inrush-currents. (0.2-0.5second delay) Any reason/s for a longer delay mechanically?
Like I said I'm not a conveyor person. As stated I saw this type drive on some very large multiple drive conveyors. Recalling some of the conversation at the time I recall that there was a big concern about the load on the belts themselves, especially the splices if an older belt. All the conveyors were in operation when I visited so I didn't get to see a startup. I do remember that the outlying belts were run form one substation so I would presume that the electric component was a big consideration in choosing the drives and the startup sequence.
Howden Buffalo used to have a very good technical section so you might give them a try.
Anecdotal:
The mine that I visited several times and where I saw these conveyors has gotten gigantic and they have become paranoid about publicity. My brother and I stopped on a public road to take a few pictures of the mine and were immediately run off by armed cowboys in black fatigues, bloused boots and big guns riding in black four wheel drive pickup.
The mine where I am working is also big with some impressive equipment, but normally it is quite easy to arrange a visit. I believe here is also a lot of cowboys, luckily not with guns! (and that is maybe a very good thing..)
I have heard one mechanical reason for a longer time-delay between multiple motors starting a conveyor. If you/someone are interested in it, check my reply on 20 Oct. in the original posting. (thread237-136811)
Thanks again for your reply.
Ralph
