Exploded Views
Exploded Views
Exploded Views
I am trying to create an exploded view of an assembly and 1 of the componants needs to move off in a direction other than the default X,Y,Z planes. It's been a while but it seems like I have done this before. Has anyone else done this? Maybe you could refresh my memory.
Mike
RE: Exploded Views
Can you move it in two steps or does it need to be in a single step?
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
RE: Exploded Views
Single step would sure be nice, but I could live with the old 2 step trick if I needed to
RE: Exploded Views
I thought it was possible to select any planar face, plane, straight edge or axis for explode direction.  Did this change?
RE: Exploded Views
Can you create a plane perpendicular to the direction needed, & use it for the explode direction?
In SW06, I beleive you can simply drag a part where required.
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions  FAQ559-1091
