2 cilinders into 1
2 cilinders into 1
Does anyone of you know, how I can make 2 cilinders into 1. I'm busy on a intake house of a motorcycle, with two intake valves. Each intake valves start alone, but they must join eachother after a while...
RE: 2 cilinders into 1
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
www.borowskiengineering.com
W.Y.T.D.N.T.Y Manual coming soon :)
"if you can't make it work...Cheat"
Perhaps the best way to do this is to model everything as a solid, such that you're working primarily with your outer surfaces in the beginning (no inside surfaces yet). Get your two tubes modeled, as you show, but leave them solid and not hollow. Create your loft to joing the figure 8 shape to your single circular shape (check help files on how to do this properly).
The final step, after all this is done, is to shell your part as Luca83 mentioned. This will eliminate the webbing between your two tubular forms automatically.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Jeff
