sample rate (audio) issues?
Hi All,
I am running the SMS algorithm, for analysing and resynthesising sound using sinusoids and filtered noise (included below for reference). I am getting a bit stuck because my resynthesised product keeps coming out at the wrong sample rate (original samples tested at 48KHz and 44.1KHz, product coming out at 22050Hz). Any advice, or global sample rate settings you can think of?
Thanks!
function SMS()
% SMS-Matlab like emulation
clear all
close all
%==== USER DATA =====
DAFx_in = wavread('love.wav'); % wave file
SR = 22050; % sampling rate
w1Length = 1024; % analysis window size
n1 = 256; % analysis window hop size
nPeaks = 90; % number of peaks detected
nSines = 50; % number of sinuosoids to track (and synthetise)
minSpacePeaks = 2; % minimum space (bins) between two picked peaks
zp = 2; % zero-padding coefficient
rgain = 1.; % gain for the residual component
MaxFreq = 11000; % maximum frequency, in Hertz, for plottings
MinMag = -100; % minimum magnitude, in dB, for plottings
%--- figure data
%fig1 = 'yes'; % if uncommented, will plot the Blackman-Harris
% window
%fig2 = 'yes'; % if uncommented, will plot the peaks detection
% and tracking in one frame
%fig3 = 'yes'; % if uncommented, will plot the peak trackings
% real-time
%fig4 = 'yes'; % if uncommented, will plot the original and
% the transformed FFT in one frame
%fig5 = 'yes'; % if uncommented, will plot the peak trackings
% only at the end of the process
%fig6 = 'yes'; % if uncommented, will plot the original signal,
% its sine and residual part, and the transformed signal
%=== Definition of the Windows ===
%--- definition of the analysis window
fConst=2*pi/(w1Length+1-1);
w1=[1:w1Length]';
w1=.35875 -.48829*cos(fConst*w1)+.14128*cos(fConst*2*w1) ...
-.01168*cos(fConst*3*w1);
w1=w1/sum(w1)*2;
N=w1Length*zp; % new size of the window
%--- synthesis window
w2=w1;
n2=n1;
%--- triangular window
wt2=triang(n2*2+1); % triangular window
%--- main lobe table of bh92
[bh92SINE2SINE,bh92SINE2SINEsize]=bh92SINE2SINEgeneration;
%--- data for the loops
frametime = n1/SR;
pin = 0;
pout = 0;
TuneLength=length(DAFx_in);
pend=TuneLength-w1Length;
%=== Definition of the data arrays ===
DAFx_in = [zeros(w1Length/2-n1-1,1); DAFx_in];
DAFx_outsine = zeros(TuneLength,1);
DAFx_outres = zeros(TuneLength,1);
%--- arrays for the partial tracking
iloc = zeros(nSines,1);
ival = zeros(nSines,1);
iphase = zeros(nSines,1);
previousiloc = zeros(nSines,1);
previousival = zeros(nSines,1);
maxSines = 400; % maximum voices for harmonizer
syniloc = zeros(maxSines,1);
synival = zeros(maxSines,1);
previoussyniloc = zeros(maxSines,1);
previousiphase = zeros(maxSines,1);
currentiphase = zeros(maxSines,1);
%--- arrays for the sinus' frequencies and amplitudes
SineFreq = zeros(nSines,ceil(TuneLength/n2));
SineAmp = zeros(nSines,ceil(TuneLength/n2));
pitch = zeros(1,1+ceil(pend/n1));
pitcherr = zeros(1,1+ceil(pend/n1));
%--- creating figures ---
if(exist('fig1'))
h = figure(1); set(h,'position', [10, 45, 200, 200]);
end
if(exist('fig2'))
h = figure(2); set(h,'position', [10, 320, 450, 350]);
axisFig2 = [0 MaxFreq MinMag 0]; zoom on;
end
if(exist('fig3'))
h = figure(3); set(h,'position', [220, 45, 550, 200]);
axisFig3 = [1 1+ceil(pend/n1) 0 MaxFreq]; zoom on;
end
if(exist('fig4'))
h = figure(4); set(h,'position', [470, 320, 450, 350]);
axisFig4 = [0 MaxFreq MinMag 0]; zoom on;
end
if(exist('fig5'))
h = figure(5); set(h,'position', [220, 45, 550, 200]);
axisFig5 = [1 1+ceil(pend/n1) 0 MaxFreq]; zoom on;
end
%--- plot the Blackman-Harris window
if(exist('fig1'))
figure(1)
plot(20*log10(abs(fftshift(fft(bh92SINE2SINE)/bh92SINE2SINEsize))))
title('Blackman-Harris window');xlabel('Samples');
ylabel('Amplitude')
end
tic
%UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
disp('analazing frame ...');
while pin<pend
%--- windowing
grain = DAFx_in(pin+1:pin+w1Length).*w1(1:w1Length);
%--- zero padding
padgrain = zeros(N,1);
padgrain(1:w1Length/2) = grain(w1Length/2+1:w1Length);
padgrain(N-w1Length/2+1:N) = grain(1:w1Length/2);
%--- fft computation
f = fft(padgrain);
r = abs(f);
phi = angle(f);
ft = r.*exp(j*phi);
%===== Analysis =====
%--- peak detection (and their plottings)
[ftloc, ftval]=PickPeaks(r(1:N/2),nPeaks,minSpacePeaks);
%--- calculate interpolated values (peak position,phase,amplitude)
[iftloc, iftphase, iftval] = ...
interpolatedValues (r,phi,N,zp,ftloc,ftval);
%--- pitch detection
[pitchvalue,pitcherror,isHarm] = ...
pitchDetection (r,N,SR,nPeaks,iftloc,iftval);
pitch(1+pin/n1) = pitchvalue*isHarm;
pitcherr(1+pin/n1) = pitcherror;
%--- peaks tracking
if (pin==0) %--- for the first frame
nNewPeaks = nSines;
else %--- creating new born tracks
for i=1:nSines
if (previousiloc(i)==0)
[previousiloc(i), previousival(i)] = CreateNewTrack ...
(iftloc, iftval, previousiloc, previousival, nSines, MinMag);
nNewPeaks = nNewPeaks - 1;
end
end
%--- simple Peak tracker
[iloc,ival,iphase,previousiloc,previousival,distminindex] = ...
peakTrackSimple(nSines,nPeaks,N,SR,pitchvalue,iftloc, ...
iftval,iftphase,isHarm,previousiloc,previousival);
end
%--- savings
previousival = ival;
previousiloc = iloc;
SineFreq(:,1+pin/n1)=max((iloc-1)/N*SR,0.);
% frequency of the partials
SineAmp(:,1+pin/n1)=max(ival, MinMag);
% amplitudes of the partials
syniloc(1:nSines) = max(1,iloc);
synival(1:nSines) = ival;
if(exist('fig3')) % plot: the trackings of partials
figure(3); clf; hold on
PlotTracking(SineFreq(:,1:1+pin/n1), pitch(1:1+pin/n1));
xlabel('Frame number');ylabel('Frequency (Hz)');
axis(axisFig3);title('Peak tracking'); drawnow
end
%--- residual computation
resfft = ft;
if(isHarm==1)
%alex
%resfft=resfft-sinefillSpectrum(iloc,ival,iphase,nSines,...
resfft=resfft-sinefillspectrum(iloc,ival,iphase,nSines,...
w1Length, zp, bh92SINE2SINE, bh92SINE2SINEsize);
end
%--- figures
if(exist('fig2'))
figure(2); clf; hold on
% plot: FFT of the windowed signal (Hz,dB)
plot((1:N/2)/N*SR, 20*log10(r(1:N/2)));
for l=1:nPeaks % plot: the peaks detected
plot([ftloc(l)-1 ftloc(l)-1]/N*SR, ...
[20*log10(ftval(l)),MinMag-1],'r:x');
end
for l=1:nSines % plot: sines tracked and the residual part
plot([iloc(l)-1, iloc(l)-1]/N*SR, [ival(l), MinMag-1],'k')
end
plot((1:N/2)/N*SR, 20*log10(abs(resfft(1:N/2))),'g');
if(isHarm) % plot: true pitch of each harmonic
for l=1:nSines
plot([pitchvalue*l, pitchvalue*l],[1, MinMag-1],'y:')
end
end
xlabel('Frequency (Hz)');ylabel('Magnitude (dB)');axis(axisFig2);
title('Peak detection and tracking for one frame'); drawnow
end
nSynSines = nSines;
%===== Transformations =====
%===== Synthesis =====
%--- phase computation
if (pin > 0)
for i=1:nSynSines
if (syniloc(i)~=0)
ifreq = (previoussyniloc(distminindex(i))+ syniloc(i))/2;
% average bin
freq = (ifreq-1)/N*SR; % freq in Hz (if loc=1 --> freq=0)
currentiphase(i)=unwrap2pi(previousiphase(distminindex(i))+...
2*pi*freq*frametime);
end
end
end
previoussynival = synival;
previoussyniloc = syniloc;
previousiphase = currentiphase;
%--- compute sine spectrum
padsynthft=sinefillspectrum(syniloc, synival, currentiphase,nSynSines,w1Length, zp, bh92SINE2SINE, bh92SINE2SINEsize);
if (isHarm==0)
padsynthft = zeros(size(padsynthft));
end
respadgrain=real(ifft(resfft));
resgrain=[respadgrain(N-w1Length/2+1:N); ...
respadgrain(1:w1Length/2)]./w2(1:w1Length);
ressynthgrain=wt2(1:n2*2).*resgrain(w1Length/2-n2:w1Length/2+n2-1);
DAFx_outres(pout+1:pout+n2*2)=DAFx_outres(pout+1:pout+n2*2)+ ...
ressynthgrain;
%--- sinusoidal computation
sinpadgrain=real(ifft(padsynthft));
singrain=[sinpadgrain(N-w1Length/2+1:N); ...
sinpadgrain(1:w1Length/2)]./w2(1:w1Length);
sinsynthgrain=wt2(1:n2*2).*singrain(w1Length/2-n2:w1Length/2+n2-1);
DAFx_outsine(pout+1:pout+n2*2)=DAFx_outsine(pout+1:pout+n2*2)+ ...
sinsynthgrain;
%--- figure with original signal and transformed signal FFT
synthr = abs(fft(respadgrain + sinpadgrain));
if(exist('fig4'))
figure(4); clf; hold on
plot((1:N/2)/N*SR, 20*log10(r(1:N/2)),'b:'); axis(axisFig4);
plot((1:N/2)/N*SR, 20*log10(synthr(1:N/2)),'r');
figure(4);
xlabel('Frequency (Hz)');ylabel('Magnitude (dB)');axis(axisFig4);
title('FFT of the original (blue) and the')
title('transformed (red) signals');
drawnow
end
%--- increment loop indexes
pin = pin + n1;
pout = pout + n2;
disp(pin/n1);
end
toc
%===== write output sounds =====
DAFx_in = DAFx_in(w1Length/2-n1:length(DAFx_in));
% remove the zeros added for the process
DAFx_outresynth = DAFx_outsine(1:TuneLength)+ ...
rgain*DAFx_outres(1:TuneLength);
mm = max(abs(DAFx_outresynth));
wavwrite(DAFx_outresynth/mm, SR, 'DAFx_out.wav');
wavwrite(DAFx_outsine/mm, SR, 'DAFx_outsine.wav');
wavwrite(DAFx_outres/mm, SR ,'DAFx_outres.wav');
if(exist('fig3')==0 & exist('fig5'))% plot: trackings of partials
figure(5); clf; hold on
PlotTracking(SineFreq(:,1:1+pend/n1), pitch(1:1+pend/n1));
xlabel('Frame number'); ylabel('Frequency (Hz)'); axis(axisFig5);
end
if(exist('fig6')) % plot the input signal, its sinus
% and its residual part, and the transformed signal
figure(6)
subplot(4,1,1); plot(DAFx_in); xlabel('input signal');
subplot(4,1,2); plot(DAFx_outsine);xlabel('sinus part');
subplot(4,1,3); plot(DAFx_outres);xlabel('residual part');
subplot(4,1,4); plot(DAFx_outresynth);
xlabel('resynthetized signal');
end
function[bh92SINE2SINE,bh92SINE2SINEsize]=bh92SINE2SINEgeneration;
%function[bh92SINE2SINE,bh92SINE2SINEsize]=bh92SINE2SINEgeneration;
% ==> generation of the Blackman-Harris window
% output data:
% bh92SINE2SINEsize: size of the window
% bh92SINE2SINE: (sampled) window
bh92SINE2SINEsize = 4096;
bh92SINE2SINE = zeros(bh92SINE2SINEsize,1);
bh92N = 512;
bh92const = [.35875, .48829, .14128, .01168];
bh92Theta = -4*2*pi/bh92N;
bh92ThetaIncr = 8*2*pi/bh92N/bh92SINE2SINEsize;
for i=1:bh92SINE2SINEsize
for m=0:3
bh92SINE2SINE(i)=bh92SINE2SINE(i)-bh92const(m+1)/2*...
(sine2sine(bh92Theta-m*2*pi/bh92N,bh92N)+...
sine2sine(bh92Theta+m*2*pi/bh92N,bh92N));
end;
bh92Theta = bh92Theta + bh92ThetaIncr;
end;
bh92SINE2SINE = bh92SINE2SINE/bh92SINE2SINE(bh92SINE2SINEsize/2+1);
function x = sine2sine( x , N )
% sine2sine function !!!
x = sin((N/2)*x) / sin(x/2);
function [loc, val] = PickPeaks(spectrum, nPeaks, minspace)
%function [loc, val] = pickpeaks(spectrum, nPeaks, minspace)
%==> peaking the nPicks highest peaks in the given spectrum
% from the greater to the lowest
% data:
% loc: bin number of peaks (if loc(i)==0, no peak detected)
% val: amplitude of the given spectrum
% spectrum: spectrum (abs(fft(signal))
% nPicks: number of peaks to pick
% minspace: minimum of space between two peaks
[r, c] = size(spectrum);
rmin = min(spectrum) - 1;
% ---find a peak, zero out the data around the peak, and repeat
val = ones(nPeaks,c)*-100;
loc = zeros(nPeaks,c);
for k=1:c %--- find all local peaks
difference = diff([rmin; spectrum(:,k); rmin]); % derivate
iloc = find(difference(1:r)>= 0 & difference(2:r+1) <= 0);
% peak locations
ival = spectrum(iloc,k); % peak values
for p=1:nPeaks
[val(p,k),l] = max(ival); % find current maximum
loc(p,k) = iloc(l); % save value and location
ind = find(abs(iloc(l)-iloc) > minspace);
% find peaks which are far away
if (isempty(ind))
break % no more local peaks to pick
end
ival = ival(ind); % shrink peak value and location array
iloc = iloc(ind);
end
end
function [iftloc, iftphase, iftval] = interpolatedValues ...
(r, phi, N, zp, ftloc, ftval)
%function [iftloc, iftphase, iftval] = interpolatedValues ...
% (r, phi, N, zp, ftloc, ftval)
%==> calculatus of the interpolated values of location (bin),
% phase and magnitude by cubic interpolation
% data:
% iftloc: interpolated location (bin)
% iftval: interpolated magnitude
% iftphase: interpolated phase
% ftloc: peak locations (bin)
% ftval: peak magnitudes
% r: modulus of the FFT
% phi: phase of the FFT
% N: size of the FFT
% zp: zero-padding multiplicative coefficient
%--- calculate interpolated peak position in bins (iftloc) ------
leftftval = r((ftloc-1).*((ftloc-1)>0)+((ftloc-1)<=0).*1);
rightftval= r((ftloc+1).*((ftloc+1)<N/2)+((ftloc+1)>=N/2).*(N/2));
leftftval = 20*log10(leftftval);
rightftval= 20*log10(rightftval);
ftval = 20*log10(ftval);
iftloc = ftloc + .5*(leftftval - rightftval) ./ ...
(leftftval - 2*ftval + rightftval);
%--- interpolated ftloc -----------------------------------------
iftloc = (iftloc>=1).*iftloc + (iftloc<1).*1;
iftloc = (iftloc>N/2+1).*(zp/2+1) + (iftloc<=N/2+1).*iftloc;
%--- calculate interpolated phase (iphase) ----------------------
leftftphase = phi(floor(iftloc));
rightftphase= phi(floor(iftloc)+1);
intpfactor = iftloc-ftloc;
intpfactor = (intpfactor>0).*intpfactor ...
+(intpfactor<0).*(1+intpfactor);
diffphase = unwrap2pi(rightftphase-leftftphase);
iftphase = leftftphase+intpfactor.*diffphase;
%--- calculate interpolate amplitude (iftval) -------------------
iftval = ftval-.25*(leftftval-rightftval).*(iftloc-ftloc);
function argunwrap = unwrap2pi (arg)
% function argunwrap = unwrap2pi (arg)
%==> unwrapping of the phase, in [-pi, pi]
% arg: phase to unwrap
arg = arg - floor(arg/2/pi)*2*pi;
argunwrap = arg - (arg>=pi)*2*pi;
function[pitchvalue,pitcherror,isHarm]=pitchDetection(r,N, ...
% function[pitchvalue,pitcherror,isHarm]= ...
% pitchDetection(r,N,SR,nPeaks,iftloc,iftval)
%==> pitch detection function, using the Two-Way Mismatch
% algorithm (see TWM.m)
% data:
% r: FFT magnitude
% SR: sampling rate
% nPeaks: number of peaks tracked
% iftloc, iftval: location (bin) and magnitude of the peak
%--- harmonicity evaluation of the signal
highenergy = sum(r(round(5000/SR*N):N/2)); % 5000 Hz to SR/2 Hz
lowenergy = sum(r(round(50/SR*N):round(2000/SR*N)));
% 50 Hz to 2000 Hz
isHarm = max(0,(highenergy/lowenergy < 0.6));
if (isHarm==1) %-- 2-way mismatch pitch estimation when harmonic
npitchpeaks = min(50,nPeaks);
[pitchvalue,pitcherror] = ...
TWM(iftloc(1:npitchpeaks),iftval(1:npitchpeaks),N,SR);
else
pitchvalue = 0;
pitcherror = 0;
end;
%--- in case of two much pitch error,
% signal supposed to be inhamonic
isHarm = min (isHarm,(pitcherror<=1.5));
function [pitch, pitcherror] = TWM (iloc, ival, N, SR)
%function [pitch, pitcherror] = TWM (iloc, ival, N, SR)
% => Two-way mismatch error pitch detection
% using Bauchamp & Maher algorithm
% data:
% iloc: location (bin) of the peaks
% ival: magnitudes of the peaks
% N: number of peaks
% SR: sampling rate
ifreq = (iloc-1)/N*SR; % frequency in Hertz
%--- avoid zero frequency peak
[zvalue,zindex] = min(ifreq);
if (zvalue==0)
ifreq(zindex) = 1;
ival(zindex) = -100;
end
ival2 = ival;
[MaxMag,MaxLoc1] = max(ival2);
ival2(MaxLoc1) = -100;
[MaxMag2,MaxLoc2]= max(ival2);
ival2(MaxLoc2) = -100;
[MaxMag3,MaxLoc3]= max(ival2);
%--- pitch candidates
nCand = 10; % number of candidates
pitchc = zeros(1,3*nCand);
pitchc(1:nCand)=(ifreq(MaxLoc1)*ones(1,nCand))./((nCand ...
+1-[1:nCand]));
pitchc(nCand+1:nCand*2)=(ifreq(MaxLoc2)*ones(1,nCand))./ ((nCand ...
+1-[1:nCand]));
pitchc(nCand*2+1:nCand*3)=(ifreq(MaxLoc3)*ones(1,nCand))./((nCand ...
+1-[1:nCand]));
%pitchc=100:300;
harmonic = pitchc;
%--- predicted to measured mismatch error
ErrorPM = zeros(fliplr(size(harmonic)));
MaxNPM = min(10,length(iloc));
for i=1:MaxNPM
difmatrixPM = harmonic' * ones(size(ifreq))';
difmatrixPM = abs(difmatrixPM ...
-ones(fliplr(size(harmonic)))*ifreq');
[FreqDistance,peakloc] = min(difmatrixPM,[],2);
Ponddif = FreqDistance .* (harmonic'.^(-0.5));
PeakMag = ival(peakloc);
MagFactor = max(0, MaxMag - PeakMag + 20);
MagFactor = max(0, 1.0 - MagFactor/75.0);
ErrorPM = ErrorPM ...
+(Ponddif+MagFactor.*(1.4*Ponddif-0.5));
harmonic = harmonic+pitchc;
end
%--- measured to predicted mismatch error
ErrorMP = zeros (fliplr(size(harmonic)));
MaxNMP = min(10,length(ifreq));
for i=1:length(pitchc)
nharm = round(ifreq(1:MaxNMP)/pitchc(i));
nharm = (nharm>=1).*nharm + (nharm<1);
FreqDistance = abs(ifreq(1:MaxNMP) - nharm*pitchc(i));
Ponddif = FreqDistance.* (ifreq(1:MaxNMP).^(-0.5));
PeakMag = ival(1:MaxNMP);
MagFactor = max(0,MaxMag - PeakMag + 20);
MagFactor = max(0,1.0 - MagFactor/75.0);
ErrorMP(i) = sum(MagFactor.*(Ponddif ...
+MagFactor.*(1.4*Ponddif-0.5)));
end
%--- total error
Error = (ErrorPM/MaxNPM) + (0.3*ErrorMP/MaxNMP);
[pitcherror, pitchindex] = min(Error);
pitch = pitchc(pitchindex);
function[iloc,ival,iphase,previousiloc,previousival, ...
distminindex]=peakTrackSimple(nSines,nPeaks,N, ...
SR,pitchvalue,iftloc,iftval,iftphase,isHarm, ...
% function[iloc,ival,iphase,previousiloc,previousival, ...
% distminindex]=peakTrackSimple(nSines,nPeaks,N, ...
% SR,pitchvalue,iftloc,iftval,iftphase,isHarm, ...
% previousiloc,previousival);
%==> simplest partial tracking
% data:
% iloc,ival,iphase: location (bin), magnitude
% and phase of peaks (current frame)
% previousiloc,previousival,previousiphase: idem for
% previous frame
% iftloc, iftval, iftphase: idem of all of the peaks in the FT
% distminindex: indexes of the minimum distance
% between iloc and iftloc
% nPeaks: number of peaks detected
% nSines: number of peaks tracked
% SR: sampling rate
% pitchvalue: estimated pitch value
% isHarm: indicator of harmonicity
tmpharm = pitchvalue; %--- temporary harmonic
MindB = -100;
ival = zeros(nSines,1) + MindB;
distminindex = zeros(nSines,1);
Delta = 0.01;
for i=1:nSines %--- for each sinus detected
if (isHarm==1) %--- for a harmonic sound
[closestpeakmag,closestpeakindex]=min(abs((iftloc-1)/N*SR-tmpharm));
tmpharm = tmpharm + pitchvalue;
else %--- for an inharmonic sound
[closestpeakmag,closestpeakindex]=min(abs(iftloc-previousiloc(i)));
end
iloc(i) = iftloc(closestpeakindex); %--- bin of the closest
ival(i) = iftval(closestpeakindex);
iphase(i) = iftphase(closestpeakindex);
dist = abs(previousiloc-iloc(i));
[distminval, distminindex(i)] = min(dist);
end
function[newiloc,newival]=CreateNewTrack(iftloc,iftval, ...
previousiloc,previousival,nSines,MinMag);
% function[newiloc,newival]=CreateNewTrack(iftloc,iftval, ...
% previousiloc,previousival,nSines,MinMag);
%==> creation of a new track by looking for a new significant
% peak not already tracked
% data: iftlov, iftval: bin number & magnitude of peaks detected
% previousiloc,
% previousival: idem for previous peaks detected
% nSines: number of sines
% MinMag: minimum magnitude (-100 dB) for
% 0 amplitude
%--- removing peaks already tracked
for i=1:nSines
[minu, ind] = min(abs(iftval - previousival(i)));
iftval(ind) = MinMag;
end
%--- keeping the maximum
[newival, ind] = max(iftval);
newiloc = iftloc(ind);
function PlotTracking(SineFreq, pitch)
%function PlotTracking(SineFreq, pitch)
%==> plot the partial tracking
% data:
% SineFreq: frequencies of the tracks
% pitch: frequency of the pitch
[nSines, nFrames] = size(SineFreq);
for n=1:nSines
f=1;
while (f<=nFrames)
while (f<=nFrames & SineFreq(n,f)==0)
f = f+1;
end
iStart = min(f,nFrames);
while (f<=nFrames & SineFreq(n,f)>0)
f = f+1;
end
iEnd = min(max(1,f-1),nFrames);
if (iEnd > iStart)
line((iStart:iEnd), SineFreq(n,iStart:iEnd));
end
end
end
h = line((1:nFrames), pitch(1:nFrames));
set(h,'linewidth', 2, 'Color', 'black');
function padsynthft=sinefillspectrum(iloc,ival,iphase,nSines, ...
%function padsynthf =sinefillspectrum(iloc,ival,iphase,nSines, ...
% w1Length, zp, bh92SINE2SINE, bh92SINE2SINEsize)
%=> compute the spectrum of all the sines in the frequency
% domain, in order to remove it from the signal
% data:
% padsynth:
% iloc, ival, iphase: location (bin), magnitude value (dB)
% and phase of a peak
% nSines: number of sines (=length of ival and iloc)
% w1Length: size of the analysis window
% bh92SINE2SINE: Blackman-Harris window
% bh92SINE2SINEsize: Blackman-Harris window size
peakmag=10.^(ival/20); % magnitude (in [0;1])
halflobe=8*zp/2-1; % bin number of the half lobe
firstbin=floor(iloc)-halflobe; % first bin for filling positive
% frequencies
firstbin2=floor(w1Length*zp-iloc+2)-halflobe;
% idem for negative frequencies
binremainder=iloc-floor(iloc);
sinphase=sin(iphase);
cosphase=cos(iphase);
findex=1-binremainder;
bh92SINE2SINEindexes =zeros(8*zp,1);
sinepadsynthft=zeros(w1Length*zp+halflobe+halflobe+1,1);
padsynthft =zeros(w1Length*zp,1);
%--- computation of the complex value
for i=1:nSines %--- for each sine
if (iloc(i)~=0) %--- JUST WORK WITH NON ZEROS VALUES OF iloc !!!
% -> tracked sines
beginindex = floor(0.5 + findex(i)*512/zp)+1;
% alex
bh92SINE2SINEindexes = [beginindex:512/zp:beginindex+512/zp*(8*zp-1)]';
%bh92SINE2SINEindexes=[beginindex:512/zp:beginindex ...
%+512/zp*(8*zp-1)]';
if (bh92SINE2SINEindexes(8*zp)>bh92SINE2SINEsize)
bh92SINE2SINEindexes(8*zp)=bh92SINE2SINEsize;
end
magsin=bh92SINE2SINE(bh92SINE2SINEindexes) ...
.*sinphase(i)*peakmag(i);
magcos=bh92SINE2SINE(bh92SINE2SINEindexes) ...
.*cosphase(i)*peakmag(i);
%--- fill positive frequency
sinepadsynthft(firstbin(i)+halflobe:firstbin(i) ...
+halflobe+8*zp-1)= ...
sinepadsynthft(firstbin(i)+halflobe:firstbin(i)+ ...
halflobe+8*zp-1)+(magcos+j*magsin);
%--- fill negative frequency
if (firstbin2(i)+halflobe <= w1Length*zp)
sinepadsynthft(firstbin2(i)+halflobe:firstbin2(i) ...
sinepadsynthft(firstbin2(i)+halflobe:firstbin2(i)+ ...
halflobe+8*zp-1)+(magcos-j*magsin);
end
end
end
%--- fill padsynthft
padsynthft=padsynthft+sinepadsynthft(halflobe+1:halflobe+1 ...
+w1Length*zp-1);
padsynthft(1:halflobe) = padsynthft(1:halflobe) + ...
sinepadsynthft(w1Length*zp+1:w1Length*zp+halflobe);
padsynthft(w1Length*zp-halflobe+1:w1Length*zp) = ...
padsynthft(w1Length*zp-halflobe+1:w1Length*zp) ...
+ sinepadsynthft(1:halflobe);
function w = triang(n)
% TRIANG Triangular window.
if rem(n,2)
% It's an odd length sequence
w = 2*(1:(n+1)/2)/(n+1);
w = [w w((n-1)/2:-1:1)]';
else
% It's even
w = (2*(1:(n+1)/2)-1)/n;
w = [w w(n/2:-1:1)]';
end
Thanks!
function SMS()
clear all
close all
%--- figure data
% window
% real-time
w1=[1:w1Length]';
w1=w1/sum(w1)*2;
w2=w1;
n2=n1;
frametime = n1/SR;
pin = 0;
pout = 0;
if(exist('fig1'))
end
if(exist('fig2'))
end
if(exist('fig3'))
end
if(exist('fig4'))
end
if(exist('fig5'))
end
if(exist('fig1'))
figure(1)
ylabel('Amplitude')
end
tic
while pin<pend
%--- windowing
%--- zero padding
f = fft(padgrain);
r = abs(f);
phi = angle(f);
ft = r.*exp(j*phi);
%--- peaks tracking
nNewPeaks = nSines;
for i=1:nSines
end
end
end
%--- savings
end
resfft = ft;
if(isHarm==1)
%alex
end
%--- figures
if(exist('fig2'))
end
end
for l=1:nSines
end
end
end
nSynSines = nSines;
if (pin > 0)
for i=1:nSynSines
if (syniloc(i)~=0)
% average bin
end
end
end
if (isHarm==0)
end
ressynthgrain;
sinsynthgrain;
if(exist('fig4'))
figure(4);
drawnow
end
pin = pin + n1;
pout = pout + n2;
disp(pin/n1);
end
toc
end
figure(6)
end
% output data:
bh92N = 512;
for m=0:3
end;
end;
% data:
% peak locations
for p=1:nPeaks
if (isempty(ind))
end
iloc = iloc(ind);
end
end
% data:
% data:
% r: FFT magnitude
% SR: sampling rate
% 50 Hz to 2000 Hz
else
pitchvalue = 0;
pitcherror = 0;
end;
% data:
% SR: sampling rate
if (zvalue==0)
ifreq(zindex) = 1;
end
ival2 = ival;
+1-[1:nCand]));
+1-[1:nCand]));
+1-[1:nCand]));
%pitchc=100:300;
harmonic = pitchc;
for i=1:MaxNPM
end
end
%--- total error
% data:
% previous frame
% SR: sampling rate
MindB = -100;
Delta = 0.01;
end
end
% previousiloc,
% 0 amplitude
for i=1:nSines
end
% data:
for n=1:nSines
f=1;
while (f<=nFrames)
f = f+1;
end
f = f+1;
end
if (iEnd > iStart)
end
end
end
% data:
% padsynth:
% frequencies
% -> tracked sines
% alex
end
end
end
end
+w1Length*zp-1);
if rem(n,2)
else
% It's even
end
