High Pressure motorized shutoff valve (NO and NC)
I am looking for motorized shutoff valves (oxygen and nitrogen gas application) operating in the 4000-6000PSI range.  Any help would be appreciated.
RE: High Pressure motorized shutoff valve (NO and NC)
What is the maximum flow rate from the valve?
Thank you for the response...I need two possible sizes: 25lb/hr and 60lb/hr.
The H27 from Habonim.com
And a Motor form Valpes.com
Or maybe HOKE.com
Best regards, tntb
