Breakout in View
Breakout in View
Breakout in View
I want to make a breakout in a view but only I only want the breakout to remove an area of 1 of the several parts in that view. Any suggestions would be gratefully received.
V5 R14 DC environment
HP C3700
UNIX
RE: Breakout in View
Have you tried using Overload properties to turn off the parts you don't want to see?...have tried it in a brekou view myself...give it a try...
it might just work
Eamonn
I am sorry but I do not know 'Overload properties' Could you please explain how to do this.
Sorry to be a pain
Right click on the drawing view
select object/overload properties
select part you would like to hide in the drawing view
characteristics dialog box appear
press edit button
uncheck the use when projecting box in the editor dialog box
repeat with every part in the drawing view
OK
Hello again
My object/overload properties is 'greyed out'. I tried to make a new view by selecting individual parts rather than the complete model but the result is the same. Is there something in tools-options which needs activating. I can find nothing
