Ideas 11m3 - Memory settings
I am using IDEAS 11M3 on UNIX station. I want to set up manually the memory settings.
Is there some rules to do this correctly accordlingly to the hardware.
Thanks for your answer.
EmL.
EmL.
RE: Ideas 11m3 - Memory settings
With regards to the ratios/percentages, for "normal use" I'd return these to how they were before you modified the Virtual Memory Limit.
Use this as a starting point and then address any memory related errors, should they arise, by adjusting the percentages. Always make sure that the percentages add up to 100% at the bottom though.
setting the Memory.AutoSetting to 0 in the global I-DEAS parameter file. The
DEFAULT location for this file is:
unix: $SDRC_INSTL/ideas/.ideas_paramX
NT4/Windows 2000: DRIVE:\team\master\config\ideas_paramX.dat
where X is the version of I-DEAS and DRIVE is the drive letter where
team is located.
