Ducted Fan Lifting capacity
I am trying to find out what a ducted fan could vertically lift. If anyone has any info that would be great, otherwise i'm going to get a scaled model ducted fan. Will set that up so i can measure fan rpm, airflow in and out. Presure of the outward flow and anything else i can and test it till i find what i want. Anyone else wanting to know this sort of information let me know and i'll keep you posted. Won't be done in a day...but then again they didn't build rome in that time either.
RE: Ducted Fan Lifting capacity
Dave
www.wsec1.com
less rigorous would be to suspend weights from your test fan and corelate lift weight with fan rpm, blade angle, fuel flow.
good luck
