shaft tool will not rotate sketch
V5R15
   I am having trouble with this simple part. First I am trying to constrain the part by defining dimensions as dia. rather than radius. The book said to right click in the geometry area and choose the Radius/Diameter option. Occasionally this would work but not most of the time. I right click but the option is not there. What am I doing wrong?
   Also this sketch is fully constrained with centerline. When I back out of sketcher and go to the shaft tool all that happens is the sketch turns white but does not revolve to form a solid. I had made this part earlier and had no problem.
   Could you explain how to include a screen shot with my text.
RE: shaft tool will not rotate sketch
Hi
Actually I re booted my machine and it works fine now. Next time I'll do that first. Thanks for the web site.
Yep, sometime its working for different problems (but not always).
Fernando
