config pro can somebody help and a few other Qs
can anyone help me with this
After reading the documentation I still cant quite get anything to start, appear or behave the way i want it to.
basically
changed and saved syscol.scl so i dont have the bland gray background
go to options then change my default templates to metric rather than imperial as its quite tedious unticking the use default template box change to read new syscol.scl file then save the file
quite where it saves i just dont know but i close wf2.0
restart and im back to square one, the default startup
hasnt changed and
im now getting a bit perturbed that i have more config.win files on my system than work
another little quirk is that every time i do a drawing of a part i use metric template,insert dims and every dimension is a max-min tolerance of the number entered for example 13mm
comes in at 12.99-13.01 not 13 im sure this can be set but i have to change every dimension manually im pulling my rapidly thinning hair out now.
and lastly is there a way to get pro to show me 13g as 13 g rather than 0.00 instead of a number to the power of i would like it to show me that 100g is a kilo not 0.001 to the power
i just like that kind of thing
anyone can help your a saint
basically
hasnt changed and
RE: config pro can somebody help and a few other Qs
The following config.pro setting will help.
pro_unit_length set to unit_mm
tol_mode set to nominal
config.win should be in the same directory as config.pro directory.
http://www.proesite.com/UTIL/2001_allopt.htm this tells you about the config settings.
Hope this helps
Tofflemire
h
This will help you out a lot...
I am pitching your product Steve.
Tofflemire
my config.pro lives in C:\Program Files\proeWildfire 2.0\jlink\jlink_appls\jlink_elev is this correct
i did a search on the system and this was the onlyconfig.pro it could find
Search back through the forum for all the possible locations for config.pro's at startup, but the one I work with most of the time is in my starting working directory. Some are project specific so I just create new desktop icons that start in the correct folder and thus load up all the options I need for that particular client or project. To have it start in that folder, copy your Pro/E shortcut icon, right click on it, and change the "Start in" location.
I recommend the 3dlogix Config.pro Mentor as well for searching through all of these options and making one that is just right for you. (kudos Steve)
Everything hunky dory now I used to know how to do this but its been 2 years since I last used pro e (using solidworks)
and Ive forgotten a hell of a lot
ps is it possible to add a note to a dimension in sketcher
for example a 200dia construction circle i want to read 200 p.c.d intead of just 200 will it then show in my drawing.
cheers mike
both guys you helps been a godsend
many thanks
Thanks for the support, your cheque is in the mail
Steve
http://www.sprdesign.com
http://www.3dlogix.com
Best regards,
Matthew Ian Loew
