Non-Engineer languages
Emailed to me with a part number from one of our product managers:
Can you identify if the following studs are double or single ended?
I replied that except for weld studs, the only single ended stud I know of works in Sales.
Then we get an invite to a company function that states:
"You must be REGISTRATED by Friday!"
.... and thay say enjuneers kan't spel.
"If A equals success, then the formula is: A = X + Y + Z, X is work. Y is play. Z is keep your mouth shut."
-- by Albert Einstein
