Corrosion of Brass hydrant components in potash solutions
I am trying to determine the most probable corrosion rates for brass hydrant components in a stagnant (treated, disinifected) water system. We are looking at a potash biocide treatment, with an estimated concentration od 100 to 150 ppm. Ideally the solution will be in contact (non-flowing) with the materials for 24-36 h.
I have limited experience with brass corrosion, and want to know (a) the most probable corrosion rates at low T (2-5 C) in (relatively) neutral conditions and (b) will there be a significant shift from what would be a normal corrosion rate (i.e. treated/disinfected water with a TRC level of roughly 0.5 - 2.0 ppm). The piping system and hydrant components are between 15 and 20 years of age.
Thanks in advance,
John
Thanks in advance,
John
RE: Corrosion of Brass hydrant components in potash solutions
good luck
