heat treat titanium (6AL-4V)
Does anyone know if Ti-6Al-4V can be heat treated to min 180KSI tensile strength?
heat treat titanium (6AL-4V)heat treat titanium (6AL-4V)(OP)
Thanks Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: heat treat titanium (6AL-4V)
Conventional heat treatment processing limits Ti 6AL-4V to about 160-KSI.
Fastener vendors claim up-to 180 KSI for "titanium bolts"... but, from various discussions... it is obvious they are using a proprietary blend of materials, thermal treatments and strain hardening of the raw-stock to "get there". Conventional machined parts would have to be fabricated from this highly processed raw-stock to have close to this strength... then risk low fracture toughness due to the extreme hardness (there will be a very small difference between FTU & FTY. If You positively need these properties, then talk with titanium fastener manufacturers that claim to have Titanium fasteners performing at the at 180 KSI sstrength level... and have them give you a fabrication proposal.
Note: hogging parts from this material would probably be a nightmare due to the incredibly hard-machining nature of titaniun... agravated by the increased strength levels.
Perhaps another Titanium alloy would be more appropriate for Your needs: there are several "newer" alloys [or with better processing] that have higher properties [+170-KSI] becoming available in plate, sheet & bar.
Regards, Wil Taylor
To go to 180 for titanium it's "usual" to go for 10-2-3, which has a MIL-HDBK-5 (ok, ok, MMPDS) condition of 180 ksi for die-forged material up to 1" thick (S-basis only). This stuff's toughness should be reasonable (40 ksi.sqrt" quoted in MIL-HDBK).
Cold reduction before after solution treating and before aging is not required for 6Al-4V Ti bolt material to achieve 160 ksi UTS. Typical aerospace bolt fabrication practice is to buy annealed material and to solution treat and age "blanks" in-house (after head forming/forging) to 160 ksi. The specifications they procure the material to require "heat treat capability" testing/certification of a sample of the as-shipped raw material after solution treament and aging (with no intermediate cold reduction) to the applicable tensile requirments.
I (like Wil) would be very, very cautious about the toughness of 6AL-4V Ti "pushed" to 180 ksi...
Igearhart: I'm not familiar with 38-6-44. I've got a bit on it in the ASMH (from 1975), but Googling it doesn't yield very much. Any other sources of info?
I sure you intended to write "solution treated and aged" condition, not "solution/annealed" condition.
