High Speed Steel Filler Rod
Can anyone suggest a supplier for either M1 or M2 high speed steel filler rod? A Google search surprisingly did not result in any welding supply houses that seem to carry these products. Thanks.
Maui
RE: High Speed Steel Filler Rod
Maui;
You might want to contact US Welding Corp
http://www.usweldingcorp.com/main.htm
These are not common off the shelf filler metals. I know that they can custom make filler metal.
Thanks Metengr. Unfortunately, they don't carry it either. But they did direct me to a company that does - High Quality Alloys located at www.hqalloys.com.
Maui
Try these two they should have something up 3/4" dia.
I was trying to look through my notes I don’t see     in particular, but Hastalloy C is a good choice on a several tool steels.  The trick is in the preheat and maintaining the interpass temperature.
http://www.cor-met.com/Default.asp
http://weldmold.com/index.htm
