Staad.Beava Influence Surface
I have been using Staad.Beava for a few months now. If everything is done in the correct order it genearally runs smoothly. The latest model I am inputing gives an error message when I try to run the influence surface generator.
"The Influence surrface results are missing or ivalid."
When I run the influence surface generator it gets to the point where it is calculating joint displacements. It never finishes and then displays the message above.
does anyone have any idea what may be causing this error?
RE: Staad.Beava Influence Surface
