Finding equations "where used"
Some here will use equations on a top level assembly, and others use equations on a sub assembly, for example:
Main Assembly (top level)
  Sub-Assembly 1
   Part 1
   Part 2
  Sub-Assembly 2
   Part 1
   Part 3
If I try to modify a dimension on a part, I get a pop-up that says "1954-02P Dimension Hole_Distance@Sketch3@1945-02P.  Part is read-only."
I don't know where the part's equation is written without opening each sub-assembly or the top-level assembly, and looking at the equations.   Either this is one of the short-falls of SW, or I am just doing it wrong.  How do ya'll handle this?
Flores
SW 2006 SP1.0
RE: Finding equations "where used"
If you open the parts you are trying to change so that it is NOT read-only, you shouldn't have the problem.
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Open part, right click on dimension, click properties, then in the upper right corner of dialog you will see “Read only” then the file name where it is used.
I only have one place it is used so do not know what would happen if used twice.
Bradley
I thought that was too easy of an answer.  By right-clicking the dimension, it tells me where the equation is being driven, but unchecking the "read only" box doesn't help.  If I uncheck the "read only" box, I can change the dimension, but whenever I go to the assembly and rebuild, it reverts back to the evaluated-equation and it automatically re-checks the "read only" checkbox on the part.
Flores
SW 2006 SP1.0
Flores,
You are right about the distance returning. With an equation, I had to use the information to find the model and delete the equation in the assembly. Then I could change it and it would keep. We used to have a button edit in contents.
Bradley
