HSS in freezing area
We have HSS columns in a freezing area -4F,(-20C). The floor is an 8 in reinforced concrete on top 2 layers of rigid insulation on top 6 in heated slab. The temperature below the heated slab is 40F,(+4C). Constant condensation is expected in the columns. How to get rid of the condensation water is our concern. Any ideas?
Thank you for your help.
RE: HSS in freezing area
SAMO,
You should provide wood blocks beneath the base plate of HSS column.
lokstr
