Coil Spring
Coil Spring
I am trying to develop a 3D coil spring. Do I use parallel circles and rotate,move them so they intersect at grips. Then trim make polyline and then use that as a path to extrude a circle. Or am I completely going down the wrong way. Any advice would be helpful
RE: Coil Spring
http://www.resourcecad.com ~ for your CAD solutions
RE: Coil Spring
Here is an example though just using AutoCAD
http://forums.augi.com/showthread.php?t=26358
