How can I implent this in matlab?
I have a file called input.dat. The file contains the following data.
0  .75
1  .23486
2  .73965
200 .648
1  .47
Basically the input file has 1-200 in order 30 times and the right column contains a num.
What I want to do is take in this file, plot all the numbers which correspond to zero in the left column, plot all the numbers which correspond to 1 in the left column etc. Does anyone know how this could be done?
RE: How can I implent this in matlab?
when you read it in you'll get a matric two colums wide by 6000 rows,so just plot the second column against the first.
Cheers
Greg Locock
Actually sorry, I just realised that I will need 3 columns (im very tired).
I cannot do that because im looking to plot all xy values where the 1st colunm is zero, then all xy values where the 1st colunm is one etc..
So in the end I will have 200 lines, each line been made from 30 points.
Sorry, you'll have to include an example of the input file, i can't see what you mean.
Cheers
Greg Locock
1   .54  .46
2   .57  .92
3   .65  .34
199  .84  .34
200  .34  .45
1    .65  .56
2    .67  .19
The left hand column will go from 0 to 200 30 times (so the file is 6000 lines long). Column 2 is my x values, column 3 is my y values.
I need to be able to plot it so line 0 will be created from all the x and y points which have a 0 in the left hand column and line 1 will be created from all the x and y points which have a 1 in the left hand column etc...
So in the end I will have plotted 200 lines, each line will be made from 30 xy points.
I hope thats clearer, thanks for your help.
I'd create a 3d array using column 1 as the page
ie new_array(x,y,page)=old_array(page,x,y);
and then plot each page as a new curve
Cheers
Greg Locock
load input.dat
[ nRow, nColumn ] = size( input );
nLine = 201;
nPage = nRow / nLine;  % You better be sure, or check here
plotData = zeros( nLine, nPage );  % malloc
for iLine = 1 : nLine
    indexZero = find( input( :, iLine ) == ( iLine - 1 ) );
    plotData( iLine, : ) = input( indexZero, 2 ).';  % Make data into a row
end
iFigure = 0;
iFigure = iFigure + 1;
figure( iFigure )
plot( plotData.' )
grid
Have I missed the point here? Is there anything wrong with this?
CODE
load input.dat;
x = reshape(input(:,2),[201,30])';
y = reshape(input(:,3),[201,30])';
plot(x,y);
M
Dr Michael F Platten
M,
There are only two coloumns in his data (the second example is incorrect it seems).  Also, the desire is to end up with a 2X2 matrix with the first colimumn being from 0:200.  Each row from the second term to the end will be the data points that correspond to the first element in that row.  There may be a clever way to vectorize using your reshape example, but I am not sure.  Otherwise, I thought a loop would be a brute force way of organizing the data.
J
Sorry, you have lost me completely there.
"... end up with a 2X2 matrix with the first colimumn being from 0:200."
I don't get what you mean by this.
"There are only two coloumns in his data (the second example is incorrect it seems)."
The OP's 3rd post seems very explicit.
"The left hand column will go from 0 to 200 30 times (so the file is 6000 lines long). Column 2 is my x values, column 3 is my y values."
The only assumption that I made was that he/she meant "6030 lines long"
M
You are correct.  I did not understand the problem.  I believe your answer is the cleanest and most efficient.
@VisiGoth - no my second example is correct, my first is wrong, I have it sorted out now anyway, thanks for your help
