removing wireframes from v4 model in Catia V5
I receive .model part data from my customer. I insert it into a CATProduct file without migrating to V5. The data includes 3D surfaces along with wireframe in which i need to get rid of the wireframe to see the part clearly. I hide/show the wireframe but that just hides the lines momentarily. They show up again when I open the file at a later time even after saving. How can I hide them until I want to see them again? Can I delete the lines points and curves and then save the file as a catproduct file?
On another note, Whjen I receive this data, It comes in severeal files that i have to combine into one file. the catch is that i don't get all parts cause two parts may be symmetrical to each other. So I need to mirror the one part to get the other. Is there a way to mirror that part without adding a new component(part file) so i can pick the correct plane to mirror with? I am inserting the .model files and want to mirror along one of the default planes not any reference planes that the user has created.
thjanks
thjanks
RE: removing wireframes from v4 model in Catia V5
and Paste Special into your CATPart either as RESULT or CATIA SPEC. Result gives you an isolated part with no history. Catia spec gives you just what it says but I have had problems if the original V4 part is not clean. Save your new CATPart as you want to see it and open that in your product.
I presume that you have no V4 access?
I copied master, pasted special both ways as result and catia spec. got rid of any ln, crv,pt as needed. Inserted that into a catproduct file along with the others. Now i need to mirror a few items that were inserted. Do I use symmetry? When I do, I get the symmetrical item on the tree, but it doesn't show up in the workspace, why?
Mirror, new instance/keep link with geometry are both highlighted. Part Body highlighted but not accessible.
After hitting finish, the only thing I see is new planes for the "newly created symmetry" that I don't see.
