What's this all about?
Whenever I want to insert anything using Smart Fasteners, I get the following error:
Error: The database file 'C:\Program Files\Common Files\Solidworks Data\lang\english\swbrowser.mdb' is not the expected version (8,6).
Any suggestions?
RE: What's this all about?
Do you have multiple versions of SW installed?
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Nope. Just 2004.
Did you do a complete & clean uninstall/install as per the FAQs?
Have you tried the Alternative to try before reinstalling  FAQ559-507?
Have you tried a Repair or Modify with the SW install discs?
My dirty hack for this problem *if* you have Access installed;
- Make a backup copy of swBrowser.mdb (i.e. swBrowser.mdb.old).  That way, you can always go back
- Open the swBrowser.mdb file.
- There is a table called 'VERSION' in the database, open it and change the value in the CurrentVersion column to the version that SW expects to see.
I would suggest trying 8.5 to see if that works.  If not, try 8.4, 8.3 etc...
I had this problem when applying a service pack to 2004 aswell.  This seemed to fix it OK.
Martin
Bassmanjax.
You're the man!!!!
Problem solved.
Thanks to all you guys for yuor suggestions.
Paul.
You do realize by hacking in *.mdb file SW will not support you, especially if the DB was to corrupt.... I know this fixed the issue, I is just want you to be aware of this.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Scott
Could you please elaborate on why SW would not support this?
BTW, this solution was arrived at by working in conjunction with my VAR.
Martin
By editing the file you could make a change that could corrupt the DB. SW will tell you straight up that they will not support a Customer that has a problem that pertains to you editing the mdb file. Now as a VAR if you send the file into them they can work with SW to help figure out the issue. But under no circumstanaces would I have one of my customers change the mdb themselves. I would change it with the help of SW, before I worked with the customer on changing the file... but that's just my Opinion.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Fair do...
Just checked out your site for the first time - nice work.  Consider it added to my list of SW resources
Have a good one
Martin
