orthotropic 3d properties to orthotropic 3d properties
Dear all,
I have properties of orthotropic 3D.But in my model I have Pshell elements. And I have to apply these properites to the pshell cards.But it is considering orthotropic 2D.
Can you plase give your view and valuable suggestion,
Thanks all
I am new user,thanks for joining this
Thanks all
RE: orthotropic 3d properties to orthotropic 3d properties
This assumes a couple of things...your model should have shell elements (thickness is small relative to overall dimensions) not bricks, you material propeties are for the lamina and you are correctly orienting each play, or your properties are smeared for the laminate and your single line input is properly oriented with the global axes.
