Rolling Element Bearing Identification
A 2MW shaft alternator was overhauled and new ball bearings fitted. The DE bearing was identified as an SKF 6232 MC3. This bearing was also the thrust.
After one hours run time this bearing failed.
After disassembly although the bearing was stamped as an SKY the design was unknown to them and was certaily spurious. However the design was such that it would have almost certainly cost more than a standard bearing to produce.
Instead of plain balls the elements were oval shaped with a 'button' on the long axis which located in a complimentary depression in the cage thus allowing the elements to rotate in one axis only and therefore could not accept the thrust when the alternator was running
Anybody have any ideas about identifying this bearing as the bearing distributor who supplied the bearing only reacts with a 1000yard stare when we try to quiz him
RE: Rolling Element Bearing Identification
6232-M/C3 bearings
American Bearing Works
615 Blue Oak Court
El Dorado Hills, Ca 95762
Orders or Info:
916 933-2450
Toll Free 800 463-2450
Fax: 916 933-2459
http://www.thrige-electric.com/pdf/lakc.pdf
Could the bearing have been installed backwards.
I assume you mean it is a thrust bearing on
the commutator side?
Does it have barrel type rollers?
I had trouble understanding what the bearing
looks like.
Certainly the bearing is in no way a 6232 bearing. Due to the design it can take no axial loading (thrust) as it is transmitted onto the cage. This we believe was the cause of failure.
Thanks for the replies so far
of the cross section of the bearing?
Of what value is the bearing part
number 6232 mc3 that you referenced?
If your roller is an oval shape, then it is not a ball bearing, but a spherical roller bearing. What you are describing almost sounds like the old New Departure Hyatt barrell roller bearing.
If you could post a picture to a web address and post the address here, I'm sure someone will be able to tell you what you have, but in any event, a 6232 is quite common and should be readily available anywhere. I assume you are the victim of a mislabled box, or a mis-identified bearing from the surplus market.
Russell Giuliano
Unique Technologies Associates - Cobra Solid Lubricant
www.uniquetechnologies.com
Please find below addresses to the photos possibly the most telling of which is the second to last
http://www.marineengineering.org.uk/Repairs/Shaft Alt (S) - damaged drive end bearing.JPG
http://www.marineengineering.org.uk/Repairs/Shaft Alt (S) - Drive end brg brass cage broken.JPG
http://www.marineengineering.org.uk/Repairs/Shaft Alt (S) - damaged Drive end brg mounted on rotor shaft.JPG
http://www.marineengineering.org.uk/Repairs/Shaft Alt (S) drive end brg - after cutting open.JPG
http://www.marineengineering.org.uk/Repairs/Shaft Alt (S) drive end brg - bearing balls found with welded on pivot cups!.JPG
http://www.marineengineering.org.uk/Repairs/Shaft Alt (S) drive end brg - close up view of broken brass cage.JPG
then selected "shaft"
and then given 4 choices and 1 gear
box pinion drive showed a bearing.
Is that the one you are talking about?
Russell Giuliano
Very sorry, the URL's contained spaces therefore would require cut and pasteing into your browser. Please try the following
http://marineengineering.org.uk/Repairs/1.JPG
http://marineengineering.org.uk/Repairs/2.JPG
http://marineengineering.org.uk/Repairs/3.JPG
http://marineengineering.org.uk/Repairs/4.JPG
http://marineengineering.org.uk/Repairs/5.JPG
http://marineengineering.org.uk/Repairs/6.JPG
of ball bearing that I have never seen
before. I assume the cages were two
piece rings riveted together to hold
the balls in place. Really seems like
an inefficient design as the balls always
track on the same surfaces whereas in
other styles the bearings with cages the
balls can rotate. How fast do the bearings
turn? I cannot tell if it is a four point
contact ball bearing with a gothic style
arch in the raceways or not. If the contact
angles were 30 degrees, the bearings could
take thrust as well as radial loads. But
I assume that this bearing was strictly
a radial design and a two point contact
bearing because of the cage design. The
bluish color of the balls I think indicates
being exposed to very high heat.
Thanks for sharing such an unusual design.
Scanned a couple of older books 30's and 40's no luck on the exact shape.
You might give these people a call as they have seen almost everything.
http://www.bmcbearing.com/services.htm
It appears that the bearing is two point contact although to be honest I am not entirely sure
The only advantage I could imagine for this style would be the accurate positioning and support of the bearing elements under high speeds although restricting their movement to one axis I would imagine makes them very susceptible to smearing. Could it be that this design prevents or at least reduces the acceleration of the bearing as it enters the load zone?
30's & 40's- crumbs!
You are right about the cage design
preventing the acceleration in the
escape from the load zone. I think
a standard cage with balls would
be just as effective and allow more
grease or oil in the bearing.
The cage design looks like overkill.
I could not get any feel on how large
the ball diameters are. I think the
bearing could be made with a filler
plug to load the balls in the id of
the inner or od of the outer. The
filler plug would be in the fixed ring
and out of the load zone. A standard
centerline cage could be used.
It may have been an angular contact bearing (7232), installed in the wrong direction. I cannot tell from the pictures, because I cannot determine if the races are equal thickness on both sides.
Russell Giuliano
shown is not an SKF 6232-M/C3 bearing.
Was the SKF bearing the one that the
manufacturer specified originally?
Do you know for a fact that you have
high axial loads? I am surprised that
it was not a roller or tapered roller
design if you had thrust loads as well
as radial loads.
Do you have a picture of the original
bearing? Why was it replaced?
Russell Giuliano
The cage design looks like it was designed
for a conrad style bearing. After the
rings were displaced and balls loaded, the
balls were then forced around the inner race
and then the cage segments were riveted together.
In the first and second pictures, are we
looking at a metal seal or is this the
cage? If the balls wore that much as shown,
then the cage would have been the carrier of
the radial loads acting on the lands of the
races. I bet this may have been someones
attempt to rework an existing design as I find
it hard to believe that a bearing company would
make such a design.
Please keep us informed about your progress.
It definitely is not a spherical roller bearing. The cage would have square openings instead of round.
Do you still have the old bearing that the distributor tried to match? If so, I would bet it is an anglular contact bearing as previously mentioned.
Mike
The 2 MW air cooled alternator was retro - fitted as a replacement for a water cooled unit that was irreperably damaged after rotor pole support failure.
The new unit was in service for 4 months when the DE bearing failed. This was original fit SKF 6232 and was mounted with spring preloading allowin a small degree of axial movement. The NDE was a 6300 series bearing and wa fixed. I could not agree more that thus design is unusual and the use of a 7000 series bearing would have been more appropriate.
However, the manufacturer indicate that several of these units are in general use and such failure is unusual.
Investigation revealed a serious misalignement probably from initial istallation as much as 11mm at the NDE from centreline- severe fretting damaged was evident on the coupling.
The shaft was damaged iwo bearing landing. A repair of sleeving with compatible material was carried out.
At this point the spurious bearing discussed was fitted. I understand that this was offered against the requirement for a 6232 MC3 although I was not privy to this.
This bearing run for 1 hour on test progressively upto 1MW electrical load without obvious fault
After a period the set was again restarted and the load quickly increased to 1.5mw and failure occurred.
Unfortunately I did not see the bearing before fitting so I cannot comment if distortion has occured to the cage. I can confirm that the bearing was without seals. The cage was made from brass in two halves and riveted together
However, the suggestion that the elements may have been distorted due to a combination of loading in excess of capacity and heat I believe to be a very valid one.
I believe that if viewed before damage then the bearing would have the general appearace of a 6232 deep groove bearing
Gentlemen, I think unless something surprising comes to light from SKF ( they have taken receipt of the bearing as I understand it was stamped as to be one of theirs) then I will post the information otherwise we can draw a line under this one.
Many thanks
Diamondjim- sorry, of course the balls accelerate out of the load zone not into it. Showing my ignorance
What you explain sound like a thrust bearing from vertical motor like a 29232 which has very little radial capacity and lots of thust in one direction only.
This bearing looks like a 6232 MC3. I have seen this type of failure before.
Scenario.
Motor rebuilt and set on line, vibrations verified OK alignment checked ok. everything doing just fine. next hour, total failure. Experienced forensic inspection.
Inner race turned blue (just like your picture)
Ball deformed (Similar to your picture)
Conclusion the fit of the inner race to the shaft was less than required interferance. Bearing sees elevated temperatures due to heat migration. fit to shaft lets go. shaft spins inside the bearing race, rapid heating, balls deform, cage breaks up. Failure. All takes place in 5 minutes or less. Question your repair company for the fit (amount of interferance) of the bearing to the shaft before install
following on from the events above the new bearing fitted has seen a steadily increaseing running temperature. More significantly the bearing has temperature fluctuations of several degrees which occur without obvious external influence.
I have suggested that this is caused by the bearing being able to move within its housing/shaft fit. I have indicated that the owner consider the repairs carried out to have failed and to start to properly plan for a period of downtime
